Differential Service
Old May 21, 2013 | 10:15 PM
Mendo XK's Avatar
Exclamation Differential Service
My 04 XKR is leaking out the axle side on the Differential 55k miles. i also want to service the Rear Axel (Suspension and Drive Line) (no leaks) on my 06 XKR 84K miles. Is putting in new seals good enough or what else should I do? How long are U-Joints good for? Anybody got some input?
Old May 22, 2013 | 03:30 AM
H20boy's Avatar
I can only tell you that I'm on original u-joints in back, but i also regreased them at about 80k. My car currently has 154k on her.
Old May 22, 2013 | 09:05 AM
oldmots's Avatar
The rear drive shafts are a CV type with enclosed boots, there is no regreasing to be done. The only repair is to replace the axle if it gets a torn boot or develops a chatter due to wear. The rear suspension and drive axles of the 04 is totally different from the 03. If the diff is leaking, I suggest having a shop repair it as this is not an easy DIY job. I also suggest that if the output seal is leaking, it won't be long for the pinion seal either, so get them all fixed at teh same time. The pinion shaft turns three times as fast as the output shaft, getting three times the wear.
Old May 22, 2013 | 09:13 AM
oldmots's Avatar
The reason for having a shop do the work is that it takes a special tool to remove the drive axle and getting to the output seal. Torn boots can be repaired but by the time you get to them, the CV is usually bad from lack of grease, so just replace the whole thing.
Old May 22, 2013 | 09:19 AM
oldmots's Avatar
OOps, ignore my comments, I thougth I was on the XJ8 thread! Sorry, the XK8 has the older lubable drive axles that form the upper arm of the suspension , but the comments on difficulty still go.
Old May 22, 2013 | 12:46 PM
H20boy's Avatar
I was beginning to wonder what i had pushed grease into. thx for clarifying oldmots.
leep123
Sep 30, 2015 03:41 PM
ChrisJay
Sep 27, 2015 09:08 AM
42Ajd
Sep 26, 2015 07:04 PM
Woznaldo
Sep 26, 2015 11:02 AM
SD96XJ6L
Sep 25, 2015 10:53 PM
