Disable alarm on XK8 ..how
Old Apr 22, 2021 | 04:01 AM
Pistnbroke's Avatar
Default Disable alarm on XK8 ..how
Is it possible to disable the alarm on the xk8 ..I took out the sounder fuse but thats not it. Can I just unplug the security module in the trunk (boot) .
Its just too loud for 2021
Old Apr 22, 2021 | 08:19 AM
bladerunner919's Avatar
Surely it shouldn't be making any noise unless it thinks someone's stealing it? Are you having a problem with it going off?
Old Apr 22, 2021 | 08:46 AM
motorcarman's Avatar
Are you trying to disable the SYSTEM or just the SOUNDER?
Old Apr 23, 2021 | 04:05 AM
Pistnbroke's Avatar
disable sounder would be fine ..pulled the fuse marked sounder and no effect .
thanks
Old Apr 23, 2021 | 09:02 AM
Just unplug the SOUNDER?
Old Apr 23, 2021 | 12:22 PM
Pistnbroke's Avatar
oh thats great but where is the sounder > Thought the horns were doing the alarm noise...!!!
Old Apr 23, 2021 | 06:48 PM
michaelh's Avatar
The sounder is in the front RHS wheel well, below the headlamp. You can see it if you remove the access panel in the liner.
The horns do most of the work if the car thinks it's being assaulted, but there's no way I'm aware of to stop that other than leaving the car unlocked or disabling/muffling the horns. Your insurance co. would not be impressed, though.
PITA really as nobody give a hoot if they hear a car alarm these days.
Old Apr 24, 2021 | 12:37 AM
Pistnbroke's Avatar
Well the horn alarm is a lot louder than a modern vehicle horn. They do bother if they are working nights or if is on a campsite at 3 am. But the advice is welcome
Old Apr 24, 2021 | 03:05 PM
I assume you have the alarm going off unexpectedly, so maybe look for the cause of that? I've never had any problems with random alarm activation, so there must be something wrong if yours is going off to the extent that you need to disable the sounder. Bear in mind that if you have an electronic problem that is the cause you should really try to find it before you have other problems or the car just immobilises itself.
Old Apr 24, 2021 | 05:46 PM
michaelh's Avatar
Indeed, I really meant that the idea is of dubious value these days due to the number of false alarms de-sensitising people.
Mine had to sleep outside for a period a few years back. It would complain bitterly in hail - which would invariably happen around 4 A.M.- so I do get your point about nuisance.
Old Apr 25, 2021 | 09:33 AM
CorStevens's Avatar
The dealer software can change the alarm settings including disabling it. One can also make it a silent arm and disarm.
Old Apr 25, 2021 | 10:21 AM
Pistnbroke's Avatar
Thank you I will go and empty my wallet and credit card into the dealer's account.
Old Apr 25, 2021 | 10:40 AM
CorStevens's Avatar
many independents have the software as well as forum members. The dealer might not charge that much as a courtesy. Sometimes it is as simple as hanging out at the shop doors around lunch break and chatting up a technician. Lots of them love the older cars and have old scan equipment at home for their side jobs, hint.
Old Apr 27, 2021 | 11:27 AM
TropicCat's Avatar
If you don't care if the horn works you can also disconnect the horn connector. I'm not sure where the horn is though. I haven't seen it while crawling around under the car but it's got to be up front somewhere. I'm sure if you set off the alarm and follow the sound you'll find it soon enough.
aliceaje
XF (X260)
Apr 25, 2021 09:32 AM
Den1948
Mar 28, 2017 03:13 PM
abwoon
Sep 5, 2009 12:54 PM
