Disappearing Hyd. Fluid??
Old Mar 22, 2021 | 04:37 PM
SamtheSham's Avatar
Default Disappearing Hyd. Fluid??
I raised the top on my '06 XK8 after noticing that it was slowed, lowering and raising the top. It reached the windshield latch and stopped. After several tries, I retired for the nite. Today I checked the fluid level and found it down 1/4" below the bottom line on the reservoir. My local mechanic says that the fluid is going somewhere, after we had filled it about 6months(15 top cycles) ago. He seems to think it could be pooling in the floor board.
I have not seen any articles on the infamous "Green Shower" for the later model XK's. Do not know if that problem was fixed on the later models???
Has anyone had a similar problem. I maybe tearing up my floor carpeting soon.
Old Mar 22, 2021 | 04:59 PM
run your hand on the lines at the pump - if they're not wet, remove the subwoofer panels and check for leakage around the rams
Old Mar 22, 2021 | 07:25 PM
RJ237's Avatar
Check the undercarriage just forward of the rear wheels. That's where the oil ends up when the cylinders leak.
Old Mar 23, 2021 | 07:22 AM
SamtheSham's Avatar
Thxs. I will get to it.
Pristine97XK8Convertible
Jun 11, 2021 05:32 PM
Scottsgreenjag
Apr 14, 2016 11:14 AM
tlynch
Oct 17, 2015 10:53 AM
Bigvettefreak
Dec 8, 2011 02:32 PM
turbo68
Mar 25, 2011 12:01 AM
