Disaster! Head bolt snaps off in block!!!!!
Old Apr 18, 2018 | 03:45 PM
dsnyder586's Avatar
BEFORE Jaguar forums: "I believe its safe to say my engine is ruined"
AFTER Jaguar forums: "it came out like butter"
Old Apr 18, 2018 | 03:58 PM
michaelh's Avatar
LOL - great to know we're not alone
@Joe - thanks for the follow-up and well done.
Old Apr 18, 2018 | 04:12 PM
johns427's Avatar
Congratulations on a successful result. Are you using new head bolts?
Old Apr 18, 2018 | 04:16 PM
rothwell's Avatar
Old Apr 19, 2018 | 01:01 PM
jobagadonuts's Avatar
Default Disaster Averted!
Sorry for the dramatic tone of my original post but the sound and feel of the bolt snapping off deep in the block was gut-churning. Mind you that prior to this the most i've done re auto repair was a few water pumps and periferals but never a complete head gasket R/R. If not for the advice and help from the forum I would have never attempted or completed the job. Thanks all!
Can't wait to be on the road again!
Old Sep 13, 2023 | 12:10 PM
aced704's Avatar
Default this worked for me
I realize this is a rather old thread, but my experience might help someone with the same problem.
Rather than using a bolt extractor or EZ-Out type of tool (I have had zero success with these in the past) I chose to use a set of left-handed drill bits (Warrior brand at Harbor Freight, about $8 for a set). The 3/16" bit had enough shank to reach the depth needed (approximately what you've shown in the photos) so I started with it. The hole I needed to operate on was the #2 on the left bank, and although the access was not terrible, the suspension tower was close enough that I couldn't fit the body of the drill in for a direct run; I bought a DrillPro 90 degree adaptor (Lowe's, about $20) to solve that problem.
I was concerned about beating up the threads inside the hole, so bought two 3/8" x 1/4" steel spacers (Lowe's, about $1 each) to line the hole.
While I was figuring this out I soaked the bolt hole with several changes of penetrating oil over a period of two days, occasionally using an old door hinge pin with a hammer to shock the bolt end loose . Before starting the operation, I hit the stuck bolt surface with a 1/4" centerpunch to help secure the end of the drill bit.
The 3/16" bit worked well (applied a few seconds at a time, on and off) and I used a small telescoping magnet to pull out the debris during the process. I finally felt the bolt end starting to come up, When that happened I switched up to the next size bit, and the bolt end zipped right out. I checked the threads by running in a new bolt (after cleaning the hole out thoroughly, using a disposable shop towel, silicone lubricant and a narrow bottle-brush). All good.
Hope this helps someone.
Last edited by aced704; Sep 13, 2023 at 12:15 PM. Reason: added info, corrected typo
Old Sep 13, 2023 | 01:02 PM
Jon89's Avatar
Well done....
Old Sep 16, 2023 | 07:09 AM
  #28
STLTHMSTA's Avatar
Well done indeed. Congrats on saving the day, neighbor. I live near Kings Island so we may not be far apart. If you ever change your shocks or top mount I have just the ticket. I'd be glad to help. TM
Peter_of_Australia
Dec 10, 2022 05:23 PM
djpxk8
Jan 7, 2022 02:28 PM
stevepaa
Jun 19, 2020 10:54 AM
jamdmyers
Mar 15, 2015 02:00 PM
timsalyer
Nov 28, 2013 01:22 PM
