Quick question?
Need to change the coolant hose from the throttle body to the three way connector at the end of the octopus hose. Also will change connector as well while I have it apart. I need to disconnect the lower electrical connector on the throttle body for better access to make the repair.
Do I need to disconnect the battery to remove a connector or two?
rothwell
close
- Join DateJan 2009
- LocationHudson, Florida
Liked:1,366 Times in 749 Posts
I don't see any need to disconnect the battery in that situation.
That connector should not be powered when the ignition is off.
That's what I figured. If the circuit is not energized I didn't see the need. However, it is a Jaguar and stranger problems seem to occur innocently.
avern1
close
- Join DateMay 2012
- LocationWinchester, CA
Liked:1,328 Times in 1,006 Posts
That is a common misconception with a Jaguar. Most of the electrical on a Jag is switched to ground and always has a live terminal when the battery is connected. Other than changing the oil and adding fluids the safest way is to always disconnect the battery before plugging or unplugging any electrical connector.
