do not overheat
Old Oct 1, 2016 | 07:33 AM
dennysjag's Avatar
Default do not overheat
I am in the process of putting a 2000 xk8 back into service that the previous owner continued to drive after blowing the hose at the norma connector. I thought I would share what an overheated aj 27 does when it drops the valve seat.
Boy does it chew up the works.
Lesson is if you blow a hose shut her down and call a tow truck. or carry a hose clamp to reconnect the hose.
I found pieces of the valve seat in the intake manifold.
Old Oct 1, 2016 | 09:34 AM
dsnyder586's Avatar
Snap.
Old Oct 1, 2016 | 10:00 AM
BobRoy's Avatar
I bet the top of the piston and the cylinder wall are damaged also.
Old Oct 1, 2016 | 11:17 AM
motorcarman's Avatar
You might also find that the pistons swelled enough to damage the nikasil bore lining and will DRINK oil when you get it running again.
Just a thought.
bob
Old Oct 1, 2016 | 12:19 PM
dennysjag's Avatar
I have no intention of trying to resurrect the motor.. Already bought and installed a 35k jag rebuilt engine. If anyone needs cams timing cover or anything other than the block and driver side head I will make such a deal you would not believe. Listed in classifieds
