Does supercharger really require spark plug replacement every 30K miles?
Old Oct 29, 2010 | 03:44 PM
eaglexkr's Avatar
Cool
Originally Posted by avos
If in doubt you could check your plugs to see how they look, that should give some indication.
I use also a heat range colder plugs (6) on my car, and my plugs look very good, so guess it will be alright.
You could also keep your plugs and add the twin-screw, that way you will have the right heat range
Yes,I have been looking at and reading up on the twinscrew after a AMG SL had me looking at its rear end!!But he felt good and his car was brand new and still had the temporary sticker on it.
Old Oct 29, 2010 | 07:23 PM
hlgeorge's Avatar
Originally Posted by Reverend Sam
And... do them one at a time. That way you don't forget which wire goes to which plug. Many years ago I made the mistake of pulling off all of the wires and replacing all of the plugs at once (on a different car). That was before the internet, and figuring out which wire went where took forever since I couldn't drive to the auto shop or library to look it up. Some lessons are never forgotten.
It would be kind of hard to mix up the wiring position on the Jag. The wire loom is attached and the little connectors to the coils are in a semi permanent position.
Old Apr 26, 2014 | 01:53 PM
worrasf's Avatar
Default Jaguar OEM plugs
Just pulled the work sheet from the dealer. Fitted the following plugs: C2A 1535
to my 2001 XKR 4.0L at 68,000 miles. Only done 73,000 so no need to change. Looking on the web these plugs are Iridium Spark Plug - C2A1535 - Genuine Jaguar at www.rimmerbros.co.uk.
They had previously fitted AJ8 4575 plugs at 43,000 (so a 30K interval) - these also show up as Iridium so I am guessing likely same plugs with updated part numbers
I presume no great difference with NGK or Denso. Likely made by them anyway and rebadged.
Steve
Old Apr 26, 2014 | 04:14 PM
auburn2's Avatar
NM
Old Apr 28, 2014 | 06:42 PM
aode06's Avatar
I don't even consider jaguar dealerships a "non warranty work repair" shop at all,due to their prices.Just a place to buy a new Jaguar.
I would find a independent foreign service shop.
Old Feb 29, 2016 | 07:20 AM
kulddy's Avatar
And the g for a 2000 XKR, 30-35 seems fight fo a boosted motor. The higher pressure usually requires a smaller gap.
xjrjag
Nov 27, 2025 09:16 AM
fast40driver
Apr 19, 2024 07:24 AM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
Drew2006
Aug 28, 2015 04:22 PM
dpappyp
Aug 27, 2015 06:31 AM
