Door fastener rivets/studs/plastic things - where can I find the right size? 2000 XK8
Old May 8, 2012 | 04:19 AM
jagosaurus's Avatar
Question Door fastener rivets/studs/plastic things - where can I find the right size? 2000 XK8
I tried to buy them from Dan Wicker, Parts Manager at Nalley Jaguar dwicker@nalleycars.com (very helpful and free shipping above $25) - but as you can see below, the black ones I got are too thick, you can get them to fit into their female counterparts, with a hammer. So no pulling out once you go in :S Which would make door panel removal very difficult and risk breaking the plastic fixtures they slot into.
Does anyone know where I can find better fitting rivets?
Old May 8, 2012 | 04:38 AM
steveinfrance's Avatar
Someone said on another post they just went to a (don't know the US name) generic car parts store, rooted through their fir tree fittings and found identical ones.
Wish we had such things in this corner of France.
Old May 8, 2012 | 05:14 AM
I recall reading the same post but didn't register the supplier details because we don't have the equivalent in the UK.
Part numbers on the last packets of XK8 door fixings I got were:
KTC100017 : Push-in Fir Tree Clip
KZV100010 : Friction Bush
Both are cream coloured.
There was a larger black Fir Tree Clip used on the front corner of the X300 front door top roll. Any chance they've supplied this by mistake?
Old May 8, 2012 | 09:21 AM
Spurlee's Avatar
Fastenall stores have a wide selection.
Old May 8, 2012 | 09:31 AM
Mountaincat's Avatar
I bought some on line for another car at clipsandfastners.com. They don't list Jaguar but you can match size.
Old May 8, 2012 | 10:04 AM
Jon89's Avatar
Our local Pep Boys sells an assortment of these types of plastic fasteners. Advance Auto Parts and Autozone probably do as well....
Old May 8, 2012 | 02:34 PM
barryl's Avatar
This might help.
I had the same search going on and gave up.
The Auto Zone chain carries a bunch of different sizes but nothing is an exact match and as you have experienced most are too large in diameter.
I got creative and ended up removing the female part of this type connector from the steel in the door and using a Fir type fastener that matched up with the existing hole in the steel door skin and it has worked well.
Barry
Old May 8, 2012 | 09:24 PM
WhiteXKR's Avatar
It is worth spending the buck or so for the correct fasteners GGG identified from a dealer.
If they are too tight, removing the door panel again can cause damage to it, if they are too loose the door panel will vibrate or come loose.
There are a a lot of close but not exact matches out there that will just cost more in time and hassle.
Old May 8, 2012 | 10:10 PM
jagosaurus's Avatar
I agree, you need to get the tolerances exactly right. Jagbits has the fasteners male and female for about a dollar each
Old Jun 20, 2018 | 05:23 PM
RichardGibbs's Avatar
Default Update on Jag Bits price
Currently these fir tree posts are going for $3.95 each and they are black instead of cream colored as mentioned earlier in this thread.
Old Jun 20, 2018 | 07:15 PM
Johnken's Avatar
I was the guy who posted that thread a while ago about getting generic ones in AutoZone or local car parts store and cutting to size. Barry has a great point if the diameter of the fastener you gets solid center section is too large. I think the main point is you can cut / shape these things aggressively. As I think about it the only parameter you can't fix with a scissors is the diameter of that solid center piece, though if you were in a jamb, you could shave it down to size. Shaving off the protruding flexible fasteners on one side will not be noticeable in any way. It'll still stick just fine. I am answering this post with a fast and loose kind of writing. Don't think modifying these guys will diminish the fastener's effectiveness, it will not and you'll be OK.
Hope this helps.
John
Old Jun 21, 2018 | 06:08 AM
Barry_Tucker's Avatar
I bought a bunch of both male and female from SNG Barratt UK ( so the US branch should be able to get them )
Old Jun 22, 2018 | 06:07 AM
R3Wood's Avatar
Deleted.
Old Jun 22, 2018 | 07:26 AM
PeterNGilbertXK8's Avatar
I got these from jagbits. I got both the male and female and ordered a few extras to keep around just in case.
Old Jun 25, 2018 | 01:49 PM
Brian XK8's Avatar
Oddly enough, I found a correct match at Home Depot of all places.
Old Jul 9, 2018 | 02:34 PM
iRuslan's Avatar
Broken fastener clips of the door card XK8. Solved for a penny.
Old Jul 24, 2018 | 08:03 PM
2000 JAGSTER's Avatar
Originally Posted by brian xk8
oddly enough, i found a correct match at home depot of all places.
@brian xk8, please provide the part number, if one, to the home depot parts ... I need both male and female for my ddriver side door . Thanx in advance
BrentGardner
29
Dec 16, 2024 12:13 AM
MJ'S Jag
Nov 10, 2022 08:14 AM
Bcrary3
Sep 3, 2015 10:54 AM
nelsonht
Aug 30, 2015 06:01 AM
peterg19
Aug 28, 2015 08:42 AM
