door glass alignment
Old May 3, 2017 | 03:29 PM
Wag's Avatar
Wag
Default door glass alignment
Hi, I just bought my 3rd x100, a 98 xkr+ paramount bits . The door glass wont re-set, even when I do the click procedure. When I raise it to the top, about 10mm from the top it does a few kerdunk noises but will only go right up if I pull it, when I open the door, it doesn't raise again when I close it . I cant tell if this is a mechanical or electrical fault. Any ideas please ? Cheers, Pat
Old May 3, 2017 | 03:34 PM
Wag's Avatar
Wag
....oh , and hi. My name is Wag, I've just bought my 3rd x100,an old xkr with paramount ecu, induction and sports exhaust . I bought it with fingers crossed off a farmer who hasn't used for about 9 months, there's a few things to do but so far so good.
Old May 3, 2017 | 04:52 PM
clyons's Avatar
Welcome to the forum.
Your problem sounds a lot like the problem member racediagnostics posted about here: https://www.jaguarforums.com/forum/x...ap-out-156573/.
Old May 3, 2017 | 05:25 PM
Wag's Avatar
Wag
Thanks Craig, seeing that nut he mentioned makes me think it could be loose and moving up and down, it seems logical. Cheers
Old May 12, 2017 | 02:56 PM
Wag's Avatar
Wag
A 2nd hand regliator arrived yesterday, I've just fitted it- all ok .The old one had three teeth worn off.
Digital Will
Feb 21, 2026 05:58 PM
Stu 1986
Sep 11, 2024 01:22 PM
rickead2000
Nov 28, 2018 12:42 PM
CyJag
38
Apr 23, 2017 10:58 PM
zigzewel
19
Dec 1, 2016 08:42 AM
