Door panel clip repair
Old Mar 29, 2016 | 10:43 AM
razorboy's Avatar
Default Door panel clip repair
Overkill?
Yes but very strong and I probably won't ever have to fix that part again.
I got a little OCD on it........lol.
BTW - In case you are wondering, that is window adhesive that I used to hold it back onto the door panel and not silicone. That black glass adhesive will hold anything to anything I swear. I had a tube from a project on my RV and wanted to use it up....lol
Old Mar 29, 2016 | 12:58 PM
dsnyder586's Avatar
I like it!
You could probably make a killing just selling the metal part for $5 each.
Old Mar 29, 2016 | 01:08 PM
razorboy's Avatar
Originally Posted by dsnyder586
I like it!
Ha,
I will leave that to someone who has a lot more time to spare than I do....lol.
The first picture shows the lame attempt at a repair that someone tried before. I cleaned off all the old epoxy and then glued the original pieces back on with crazy glue. This gave me a foundation to build the bracket over. There was a little space between the metal and the plastic part so I just filled that space with a little epoxy and now it is very solid.
Also just discovered that the other two plastic holders on that side of the door panel have been partially pulled away from the door panel. Someone got too aggressive on the panel in the past I assume?
Time to whip out the window adhesive again to make sure those stay tight.
JimC64
Mar 29, 2016 09:50 AM
EscapedApe
Mar 19, 2016 01:28 PM
chiefM
Mar 11, 2016 07:17 AM
Tonyj
Mar 5, 2016 02:44 AM
magnum454
Mar 1, 2016 06:27 PM
