door window fault
Old Nov 9, 2011 | 02:03 PM
dennisw's Avatar
Default door window fault
opened the passenger door on my car today to get somthing out ,when I shut the door it would not shut properly..the window was fully up so the glass was hitting the trim.when you pull the handle even with the door open the glass goes down about half inch when release it goes back up..have to let the window down from the drivers controls to shut door the sent it up..tried to reset but still the same..any help would be usefull..
the big hammer is standing by
looked at sams videos and know how to remove panel and adjust window..going to have a go thursday
Old Nov 9, 2011 | 02:18 PM
WhiteXKR's Avatar
Sounds more like an electronic issue..do not do any mechanical adjustments yet or you might create bigger headaches.
-How are you doing the 'reset'
-What is the voltage across your battery terminals?
Old Nov 9, 2011 | 02:26 PM
dennisw's Avatar
thanks for the quick reply..
ignition on window all the way down still holding button wait for click.. window all the way up still holding button..wait for click..
done this before so I know im doing it ok..done it on the drivers door when its lost its mem..battery in good condition..winter here so i make sure batt 100%..any ideas?
Old Nov 9, 2011 | 02:32 PM
WhiteXKR's Avatar
Is the door shut when you do the reset procedure?
Also, check your battery engine off with a digital meter...anything less than 12.5 volts would be suspect.
Old Nov 9, 2011 | 02:34 PM
dennisw's Avatar
yes door shut for reset will check batt in the morning with a meter and repost..thanks for your replys
Old Nov 9, 2011 | 02:40 PM
dennisw's Avatar
because its cold now its winter..this morning i had the heated seat..rear window demist..stereo.. heater..and i only make short trip to work and back..could be low batt.will charge at work in morning..thanks
Old Nov 9, 2011 | 02:44 PM
WhiteXKR's Avatar
The window is sometimes the low battery indicator on the XK
Old Nov 9, 2011 | 04:10 PM
Paul Pavlik's Avatar
Well known problem.The "Door Open" Switch in the lock assembly (inside the door) has failed. A number of posts on this. There are several switches on the Lock Assembly.
Old Nov 9, 2011 | 04:21 PM
WhiteXKR's Avatar
Agreed, but a battery check is prudent before diving into the door.
Old Nov 9, 2011 | 08:41 PM
Reverend Sam's Avatar
When you open the door do the interior lights come on, and do you get a message in the display that says the door is open? If not, you have a bad switch in the door latch. I have a video which shows how to replace it.
Old Nov 10, 2011 | 09:20 AM
dennisw's Avatar
Sam..looked at your vids cant find one that shows how to fix switch problem only one that shows how to adjust window so that you can shut the door..HELP may be i cant see the woods for the trees
Old Nov 10, 2011 | 11:31 AM
dennisw's Avatar
found it..cant see for lookin..very good thanks
Old Nov 10, 2011 | 11:40 AM
dennisw's Avatar
I have found a door lock mech that may be the one i need.. but need help the part number for the one ive found is GJA1081FJ is this the one for a 02 xkr?the one on my parts list has dg instead of fj any one know
Old Nov 10, 2011 | 01:27 PM
You don't need to buy the whole latch. The switch itself is available separately. The part number is in another thread somewhere.
Old Nov 10, 2011 | 01:40 PM
dennisw's Avatar
thanks sam ill look for it
Old Nov 10, 2011 | 01:51 PM
dennisw's Avatar
found th post
printed it out will get swich and have a go
many thanks
Old Nov 10, 2011 | 03:43 PM
pophen's Avatar
I would have bet the ranch that the battery was getting weak. That's the way my windows acted when the guage showed less then 11 volts with ignition on and dropped to 10 volts while cranking. New battery problem solved. Jack
Old Nov 11, 2011 | 09:26 AM
dennisw's Avatar
ordered 2 switches will be here wednesday..if you look into the lock from the side you can see thr switch..mine has now gone intermitant so come on now and again and sets the alarm off..will have to take it out intill the new ones arrive
Old Nov 11, 2011 | 09:45 AM
The hardest part about removing the latch is getting the rods that go from the outside handle down to the latch disconnected. The ends are made of plastic and they just snap on to the latch mechanism, but it is hard to pop them off, and I ended up breaking one of the plastic bits in the process. I was able to repair it simply by drilling a hole in the plastic piece, then I lined up the hole I had drilled with the hole in the lever on the latch and I zip tied them together.
Old Nov 11, 2011 | 09:46 AM
I actually like that big font we used above. I'm apparently going to need reading glasses soon.
