Drivers door window out of sync on convertible
Old May 3, 2017 | 08:18 AM
justenough's Avatar
Default Drivers door window out of sync on convertible
My 97 xk8 convertible drivers window is out of sync when I pull on my door handles. The window no longer goes up or down automatically, help.
Old May 3, 2017 | 08:45 AM
deovolente's Avatar
Have you tried the reset? With key in ignition position I or II, run window down and keep holding the switch for a few seconds until you hear a click. Then run it all the way up and keep holding the switch for a few seconds until you hear the click.
Old May 3, 2017 | 09:30 AM
Check the battery also, the window is one of the first signs of it going south.
Old May 3, 2017 | 12:47 PM
No auto drop/lift movement can be Door Module fault or microswitch failure in the Door Latch.
Old May 3, 2017 | 07:21 PM
justenough's Avatar
Thanks I will first try the reset then if necessary disconnect the battery and discharge any capacitors in the system. If that does not work I will remove the door panel and locate the microswitch and door module. Any chance you might know where I might find part numbers for these two items and how can I test them?
Old May 3, 2017 | 08:17 PM
Jandreu's Avatar
See this thread starting at post 6 for the micro switch replacement.
https://www.jaguarforums.com/forum/x...roject-118210/
Old Feb 7, 2018 | 01:42 PM
TwinWire's Avatar
Thanks for this hint. I just joined, and was searching posts because my 2002 XK8 windows were not operating properly after a battery change. I thought I had reset them, per the operator's manual, but missed the "click". Resetting again, this time with a "click", solved the problem. Thanks!
itswemy
Nov 22, 2016 02:59 AM
Jag nut
Feb 21, 2016 07:09 PM
Jag13cat
Nov 30, 2015 06:48 AM
Michaelson0101
Nov 5, 2013 03:40 AM
