Driver's window problem
Old Feb 14, 2011 | 03:07 PM
RichmondXK's Avatar
Default Driver's window problem
After sitting in the garage for 2 months, I took the Jag out today and have a problem w/ the driver's window. When I open the door, the window goes down a fraction of an inch. But, when I close the door, the window does not roll back up. So, if I open the door multiple times, the window ends up almost all the way down.
Anyone else have this issue? Is it an easy fix?
Old Feb 14, 2011 | 03:13 PM
Reverend Sam's Avatar
You just need to reset the window. The passenger window is probably doing the same thing. Just roll it all the way down until it stops, then continue holding the switch for another 3 seconds or so until you hear a little click. Then roll it all the way up and once it stops continue holding the switch for 3 more seconds until you hear another click. That's all their is to it.
Any time the battery goes dead or you disconnect it you will have to reprogram the windows.
Old Feb 14, 2011 | 03:18 PM
RichmondXK's Avatar
Actually, i just checked and it's both the drivers and passenger windows that now dont work properly.
Old Feb 14, 2011 | 03:31 PM
See my prior post. Between your first and second posts.
Old Feb 14, 2011 | 06:11 PM
RichmondXK's Avatar
thanks. The windows are working perfectly now.
Old Feb 14, 2011 | 07:58 PM
Good! That's the easiest fix ever. Any time you disconnect the battery you'll have to do it again.
Old Feb 15, 2011 | 10:41 AM
H20boy's Avatar
...or it sits that long! A good investment, in periods of long storage (i'd say over a month) is to get a battery tender, it'll keep your radio stations in tact, your windows won't need programmed, and you won't be locked out of your boot either in a battery drain situation...especially if your jumper cables are in the boot!
Old Feb 15, 2011 | 06:52 PM
I second h20boy's advice. I bought a decent battery charger/starter at Harbor Freight for only $25 with a coupon, but I've seen a couple of trickle chargers since then for $10-$15. They were little tiny things, not like the big thing I bought. They won't start your car if the battery is dead, but they'll keep the battery from going dead. If I remember correctly, one of them even plugged into your cigarette lighter so you didn't have to access the battery in the trunk.
Old May 22, 2011 | 08:33 AM
David's XKR's Avatar
This and all the other auto forums are great! I just had the same issue with my windows and here's the answer. I left the lights on and it ran down the battery. What's odd is if the headlights are left on the alarm sounds. But I just left the parking lights on and there wasn't an alarm.
Old May 22, 2011 | 12:06 PM
pophen's Avatar
Richmond XK, the window are also a good indicator that your battery is getting old and weak. If you can't get them to reprogram next step is to get the battery checked. Jack
99xk8guy
Sep 29, 2025 10:51 PM
mcdutch
Sep 4, 2015 03:38 AM
philwarner
Sep 3, 2015 10:14 PM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
