DSC and engine system fault while drivimg
Old May 7, 2021 | 09:21 PM
Salim1luv's Avatar
Default DSC and engine system fault while drivimg
I was driving up the highway about 3 miles, did 70mph max. Then as i got off exit, a dsc message and engine system fault message, came up and the engine almost shut off and the car wouldnt accelerate. I manage to pull over,stopped and turned off the car, then restarted and it ran fine. Then i headed back home and it did the exact same thing as i was pulling in to my driveway. Anyone with insight,can anyone tell me why?
Old May 8, 2021 | 01:06 AM
JagV8's Avatar
It needs a reliable source of speed and relies on the ABS (DSC) which gets it from the speed sensors. One is probably dirty/failing. Get codes from ABS module.
Old May 11, 2021 | 12:16 AM
CA Jag's Avatar
Dirty or connection problems w/ sensors seem to be the usual problem. Has anyone else had problems w/ a defective ABS module? Got C1095 so shop replaced w/ a rebuilt. End of problem.
Chantel Clayton
Sep 27, 2020 05:38 PM
capitolexchange
Apr 22, 2014 12:26 PM
Jagfan1981
Jun 13, 2012 11:02 PM
CortComp
Feb 12, 2012 07:41 PM
