Dsc fault + erratic mirror adjustments + non-operative steering wheel retracting +...
Old Jun 22, 2019 | 07:12 PM
wymjym's Avatar
Default Dsc fault + erratic mirror adjustments + non-operative steering wheel retracting +...
Dsc fault + erratic mirror adjustments + non-operative steering wheel retracting + sluggish shifting
Several months ago I started getting no abs warnings, which would go away if I restarted. I always have a tender on the battery but was curious, I check the voltage and it was low…12.2.
I kept that in mind and lived with the nuisance.
Several weeks ago the car quit giving the abs fault and only a dsc fault…this one would not go away. I also noticed the steering wheel wasn’t retracting any longer, I checked the voltage and it was 11.9.
So
New Bosch Battery, 13.2 volts and everything works as it should.
The big surprise to me was that the lower voltage actually affected the transmission shifting points and reaction to throttle movement.
So…until someone wants to gold plate all the electrical connectors in our X100s I think a healthy battery is the smart way to go.
I just wanted to continue to underscore the battery thing for anyone in doubt.
wj
Old Jun 23, 2019 | 04:41 AM
frankc's Avatar
So
wj
I second that. Once the battery voltage drops you get loads of weird and wonderful effects. These cars are VERY susceptible to voltage drop effects.
alephzain
16
Mar 1, 2019 06:00 PM
StevenVdl
Apr 12, 2015 01:44 PM
johndahlheimer
Sep 11, 2014 03:27 PM
Spikepaga
Mar 22, 2014 03:32 PM
lc2000
Dec 30, 2008 06:37 AM
