Dumb question - what goes in this hole?
Old Aug 1, 2010 | 08:52 AM
Dave S's Avatar
Default Dumb question - what goes in this hole?
Was doing some work on my car yesterday (installed the antenna switch, failed to remove my stuck passenger seat, cleaned out the throttle assembly, and tightened up the throttle cable) and I noticed this empty tube. I'm not even sure of where on JTIS to look it up as I don't know what is is. But it looks like it should have something in the opening?
What is it? What should go in there?
Dave
Old Aug 1, 2010 | 09:50 AM
WhiteXKR's Avatar
Yikes, Dave, thats your transmission dipstick tube. It is supposed to be capped. You can get the cap and lock pin from the Jag dealer, or since it is a Mercedes transmission, cheaper from here:
http://www.rmeuropean.com/Part-Numbe..._5C1313F8.aspx and http://www.rmeuropean.com/Part-Numbe..._5C1313F8.aspx.
Since it has been running uncapped, you probably should think seriously about a fluid flush.
Old Aug 1, 2010 | 02:08 PM
2002XK8Orlando's Avatar
Is the trans in the xk8 a Benz trans as well or a BMW?
Old Aug 1, 2010 | 02:46 PM
MrTexasDan's Avatar
ZF 5-speed through 2002
ZF 6-speed 2003-
Old Aug 1, 2010 | 11:29 PM
H20boy's Avatar
Yah, I think the benz tranny was in the XKR from 99 (or was 2000 the first year?) to 2002. Once it got to 2003 and up, ZF took both 8s and Rs, right?
Old Aug 2, 2010 | 12:47 AM
MrTexasDan's Avatar
Right-o H2o !
PMKimpton
Aug 3, 2019 08:22 PM
chatmanx
Sep 11, 2015 07:17 PM
mrplow58
Sep 9, 2015 11:27 AM
kstevusa
Sep 7, 2015 01:12 PM
deanh
Sep 6, 2015 08:20 PM
