Dunfounded
Old May 21, 2017 | 03:57 PM
Doug Gordon's Avatar
Default Dunfounded
Code C1637 any ideas what or how to correct this? Has something to do with the ABS system. 2002 XK8 4.0 And do I need a new module? Help me please I'm totally lost on this one!
Old May 21, 2017 | 04:09 PM
RDMinor's Avatar
Are you positive it's a C1637 and not a P1637?
Old May 21, 2017 | 04:51 PM
yes. I even double checked . just took her for a drive showing engine light , dash says track not available and ASC not available along with the Abs light. I'm assuming that the Asc is the cruise control because that's not working .
Old May 21, 2017 | 04:54 PM
jimbov8's Avatar
Start by ensuring the battery is fully charged then try again.
Old May 21, 2017 | 04:59 PM
just put in a brand new battery. 2 week ago the best Bosch platinum series!
Old May 21, 2017 | 05:55 PM
According to the Jaguar DTC Summaries, C1637 is not an assigned error code for the 2002MY XK8.
Old May 21, 2017 | 06:27 PM
thanks Graham , I just checked with the mechanic who owns the snap on scaner and he said it was a c1637. He headed to his garage to look it up .he told me thats what it was showing. He'll call me back and I'll let you know.
RJ237's Avatar
What code reader are you using to get this C code?
Old May 21, 2017 | 06:29 PM
its a snap -on
Old May 21, 2017 | 07:01 PM
all right here the deal ,it was showing a P1637 before he cleared the engine codes ,an then going thru the hole system, he found code C1137 which pretty much says the same thing . ( no can signal from ABS module) what ever that means. I can only guess that my Abs module has taken a crap! Now the question is, where the best place to get a repop?
Old May 21, 2017 | 07:06 PM
your right , had a p1637 cleared it out then it was showing a new code C1137. Pretty much the same thing! ABS Module is shot. Now where's the best place to get a repop?
Old May 21, 2017 | 08:45 PM
StuG's Avatar
Hi Doug,
It's probably just dodgy solder joints in the ABS module. You can get it rebuilt in a couple of weeks or less. Way cheaper than trying to source a new one.
1998-2003 Jaguar XJ8 XKR XK8 ABS Module Repair Rebuild Sevice | eBay
Cheers,
Stu
Old May 21, 2017 | 08:55 PM
motorcarman's Avatar
Why are there 2 different posts on this same subject?????????????????????????????????????
bob
Old May 22, 2017 | 03:56 AM
Originally Posted by StuG
Hi Doug,
1998-2003 Jaguar XJ8 XKR XK8 ABS Module Repair Rebuild Sevice eBay
Cheers,
Stu
allready solder them , thanks Stu
Old May 22, 2017 | 03:58 AM
bob
sorry Bob I Think it's my fault
