ECU Swap?
Old Jun 2, 2025 | 09:53 PM
2500DollarXKR's Avatar
Default ECU Swap?
I'm chasing down some relatively minor electrical issues, one of which is an intermittent failure for the TCM and ECU to communicate. This is not causing issues, but I'm ruling out stuff nonetheless. I have a new (salvage) ECU coming in, same part #, same year, XKR. Is it a simple swap over or do I need to worry about programming?
Old Jun 3, 2025 | 03:13 AM
JagV8's Avatar
I think it will not be but see what others say / Search forum.
Old Jun 3, 2025 | 03:50 AM
dibbit's Avatar
You will need to do the immobiliser setup in WDS/IDS unless your car is one of the few that doesn't have a chip in the keys. I think you can do this in some of the aftermarket scanners also, if you don't have Jaguar's version.
No harm in swapping and seeing if the car starts though.
juha_teuvonnen
May 24, 2023 12:43 PM
julien4020
May 2, 2015 12:52 PM
adam699
Nov 25, 2012 09:55 AM
rweber
Nov 18, 2010 10:48 AM
BaDAss03STR
Sep 10, 2008 02:57 AM
