Electrical issue
Old Feb 23, 2026 | 09:30 AM
Jimco1's Avatar
Default Electrical issue
Have to ask for a little help when I got this car is was and still is pretty dead. I have replaced the battery and have the radio and fan working but every other system is still dead windows, roof, lights and starter. I have checked every fuse and have power to every fuse box that is shown for this car and all are good. Any ideas on where to look I am pretty good with this kind of stuff keep a range rover going for 20 years and had to rewire door panels and alarm system to keep it running. But I am at a loss as what to check next any ideas. I plan to ask this question in another place in case it does not belong here. This is the other place, 1999 XK8
Old Feb 23, 2026 | 11:48 AM
Pantera928's Avatar
Do you have a good OBD scanner like Icarsoft or Foxwell? You might run some full scans to see what info you get back
Old Feb 23, 2026 | 12:58 PM
michaelh's Avatar
I guess you've no real information on the car's history. With so many issues, there may be a problem with one of the car's networks (thinking SCP possibly).
As above, I'd recommend you invest in an OBD reader as a first step.
P.S. You've done the correct thing by starting this new thread as your other isn't relevant to this issue
Old Feb 23, 2026 | 01:57 PM
2500DollarXKR's Avatar
Let's think about this from a logic perspective...you've got radio and fan. So you've got power going to both the back and the front of the car. What's not working is ALSO in the back or front of the car. What would keep windows from rolling up? What would keep a top from functioning? What would tell the ECU "under no circumstances start this car"? My guess? Body Processor Module in the footwell has become damaged or disconnected. Invest in a iCarsoft reader and it'll tell ya.
Old Feb 23, 2026 | 03:48 PM
Jimco1's Avatar
Which reader is recommended don’t mind buying one have several cheap ones had a good one that was for the rover only left it go with car.
Old Feb 23, 2026 | 03:57 PM
michaelh's Avatar
Read the car with the one you have and see what it returns. Post any codes it returns up here:- just the codes, not any text interpretation of them.
For something more advanced, the icarsoft mentioned by $2500 & Pantera seems popular - LR1, I think? There are others - lots of opinions, thankfully not as many as 'which oil should I use'
Old Feb 23, 2026 | 04:11 PM
Jimco1's Avatar
Just ordered a iCarsoft
Bidirectional Scan Tool CR Pro+ see what it says in 2 days
Old Feb 23, 2026 | 04:30 PM
Pantera928's Avatar
I have both the icarsoft and the Foxwell. My icarsoft is loaded with software specifically for Jaguar/Landrover
I also have JLRSDD software on a laptop but for most things, it is not necessary
Old Feb 23, 2026 | 05:12 PM
Jimco1's Avatar
Tried ones I had 1st one could not communicate, 2nd one gave codes 560, 1638, and 1646, next one gave 1646,1638,560 and 1000 last reader would not do anything.
Old Feb 24, 2026 | 12:32 AM
Gnorty's Avatar
I have an ebay Bluetooth OBD2 adapter and the JLR iCarSoft reader. the bluetooth adapter and Torque Pro app is amazing for reading from the ECU but cannot read anything else. The iCarsoft reader is (IMO) inferior for the ECU, but is capable of reading all the other modules beside the ECU.
Old Feb 24, 2026 | 01:26 AM
zray's Avatar
What is your step by step procedure for trying to use the icarsoft to read the ECU module ?
Z
Old Feb 24, 2026 | 03:09 AM
JagV8's Avatar
In future, please state the full code. If those were P codes then there are threads you can read with fixes. Also get your car's jag doc from JagRepair.com - Jaguar Repair Information Resource
Old Feb 24, 2026 | 11:01 AM
Jimco1's Avatar
They were all P codes thought I was asked to just post the codes I got without any thing else, when I get the new reader tomorrow I will troubleshoot from that. Do not mind doing the work was just asking for a starting point to check this out.
Old Feb 24, 2026 | 03:36 PM
michaelh's Avatar
That's probably my bad for saying don't include text Readers usually include a description as well as the code, but said descriptions are often incorrect.
The prefix is important, as you will likely see with the iCarsoft. Expect C, B and U in addition to P-codes.
OK - forget the readers that don't communicate. You can also ignore the P1000 for now, as that's just telling you that the Onboard Monitoring tests haven't completed (happens when the battery is disconnected or the codes are cleared).
Here's a snip from the DTC list for the other codes you have:
At this stage, those codes don't explain why the car is dead, although I'd double check the fuses and relay in the Engine Management fusebox re the P0560 (the ECM partly controls power to itself so it can perform shutdown tasks after the ignition is switched off).
However, at least it's reporting something. Suggest you clear the codes, and re-read to see which re-occur. As you've changed the battery, check that you have around 12.6 volts across the battery terminals at rest. These care are very particular about battery voltage.
Since you don't have the backstory, it can be challenging to troubleshoot - entirely possible as suggested that someone left something disconnected. Just keep on eliminating things. Any signs of rodent damage?
Old Feb 24, 2026 | 06:37 PM
Jimco1's Avatar
No sign of rodent damage just signs the car has been outside for a long time. When I get the better reader I will get in gear and try to really get into this I enjoy a challenge. That was my bad on the codes I knew what you were asking I just forgot to put the P in front of the codes.
Old Feb 25, 2026 | 03:02 AM
dibbit's Avatar
While you are waiting for your better code reader, I think I would be checking power and grounds again all round the car with a test bulb, rather than a multimeter. It sounds most likely that you don't have good power or ground somewhere vital when the ignition switch is on. Either way it costs nothing to check.
Old Feb 25, 2026 | 03:45 AM
JagV8's Avatar
I don't know this era car but does it have PATS?
If it does and it chooses not to start it will flash a code saying why.
Old Feb 25, 2026 | 04:09 AM
dibbit's Avatar
He said windows and lights don't work - there is something much more basic wrong with the car.
Old Feb 25, 2026 | 06:26 AM
JagV8's Avatar
I agree but maybe still get PATS? Not hard to check.
Old Feb 25, 2026 | 09:33 AM
dibbit's Avatar
True. I think the only indication would be the red led by the gear lever on the 4.0 cars which blinks when locked - maybe the OP can tell us what it is doing?
