Engine fault 1997 XK8
Old Apr 27, 2013 | 08:04 AM
noterman's Avatar
Default Engine fault 1997 XK8
I finally fixed my transmission problem. It was the TCM. Took the car for a test drive and all went well. About a mile from home I decided to give it full throttle to see how the trans would handle it. After the shift to third at the redline I got an engine fault light with reduced performance. Came home and unhooked the battery and put the pos and neg together to try and reset the computer. I left it that way for 5 minutes. Hooked her back up and still have the engine fault light. Was that long enough to reset the computer? The engine sounds fine, but you can tell its at reduced performance. I just replaced the secondary chain tensioners before the test drive.
Old Apr 27, 2013 | 08:07 AM
WhiteXKR's Avatar
Your reset was OK. You really need to read the OBDII codes to get a clue as to the reason for the reduced performance.
toronadomike
Jan 22, 2026 10:13 PM
99xk8guy
Sep 29, 2025 10:51 PM
D.K
Dec 10, 2023 02:05 AM
arnoldmilk
Sep 3, 2015 07:42 PM
OkieTim
Sep 2, 2015 12:48 PM
