Engine Knock on 2007 XK
Old May 4, 2009 | 02:53 PM
test point's Avatar
I have a few personal thoughts . . . unencumbered by any real knowledge, training or experience:
The Jaguar engine should not experience any discernable knock under any conditions. This past Fall during the great gas shortage only regular grade (87) was available for several weeks. I never heard any sign of engine knock on my '02 4.0L XK8. And you can believe that I listened closely.
The knock sensors should handle any knock that does occur.
Engine knocking is the most damaging thing an engine can experience.
I have never seen a Jaguar Dealer hesident to preform any warranty repairs and questioned why some were done.
Old May 4, 2009 | 03:13 PM
SeismicGuy's Avatar
Also, many cars over the last 10 years (with fuel injection and computer monitoring) are able to adjust fuel and timing curves to deal with different octane ratings. The last car I had that knocked was at least 20 years ago.
Doug
Old May 4, 2009 | 08:28 PM
remosusa's Avatar
Is it mechanical knock, or engine ping (detonation). Engine ping should be fixed through the knock sensor so fast you could hardly tell. Mechanical knock could be caused by many things... the funny part is that a mechanical knock can also trigger the knock sensor to retard the timing. Ping is usually experienced when speeding up, under load... going up a hill, etc. is this your case? If it's ping, and it's so bad that engine damage is going to happen, usually you'll see signs on the spark plugs. During the first few years of unleaded gas, we all had to learn all about ping... If you believe it's ping, and you have ping symtoms (acceleration, uphill, etc) have you tried octane booster and re-tested?
Rlover
Mar 30, 2016 10:04 PM
jdzubas
Oct 4, 2015 09:14 AM
robiwhan
Sep 4, 2015 10:43 AM
mcdutch
Sep 4, 2015 03:38 AM
obwoodie
Sep 3, 2015 07:45 PM
