Engine rotates clockwise looking from front?
Old Jul 28, 2008 | 04:07 PM
GordoCatCar's Avatar
Default Engine rotates clockwise looking from front?
Looking at the engine from the front, the motor rotates clockwise, correct?
I am tightening up primary tensioners and chains.
Is the 'driven' side, the side pulled by the crank. That side has the flat chain guide and is not the side associated with the tensioner and the curved blade??
Gordo
Old Jul 29, 2008 | 06:36 PM
jag_genius's Avatar
Default RE: Engine rotates clockwise looking from front?
yes turns clockwise . when looking from the front in fornt of rad. correct on question2...
When your done.. looking from the front. starting from drivers side.. you will have a tight chain.. then to the left of that ...tensioned chain with primary tensioner(bank 2)with curved blade.. then to the left of that ..tight chain then left of that tensioned chain (bank 1) with primary tensioners curved blade..
Old Jul 29, 2008 | 09:18 PM
Thanks J-G
DavidNagel
Dec 29, 2017 09:16 PM
jdzubas
Oct 4, 2015 09:14 AM
Fraser Mitchell
Oct 1, 2015 04:06 AM
GreyXK
Aug 31, 2015 05:15 PM
timm525
Aug 29, 2015 04:49 PM
