Engine wont start after disconnect courtsey unit disconnect
Old Jul 24, 2011 | 03:33 PM
LedZepplin's Avatar
Default Engine wont start after disconnect courtsey unit disconnect
Hi
I disconnected the courtesy light until above the mirror this afternoon and removed the unit with the micro phones in it to bend back the mesh. I reconnected it all and replaced, all lights work fine e.t.c But now the engine wont start. Ignition lights come on with no warning light but then engine does not turn over. Yes I had my foot on the brake and it was in park.
Any ideas I'm guessing its something to do with me disconnecting that unit as it must be connected to the alarm system.
Car worked fine before no problems its a 2001 XKR with 50K miles.
Old Jul 24, 2011 | 04:43 PM
Gus's Avatar
Gus
I have no idea but would like to know what you find.
Old Jul 24, 2011 | 04:55 PM
WhiteXKR's Avatar
Try disconnecting and then reconnecting the battery after 30 seconds.
Old Jul 24, 2011 | 05:13 PM
LedZepplin's Avatar
Default OK fixed
OK wife fixed this one she said check ya fuses. After checking boot and two boxes under the bonnet then checked the one in the drivers side door and it was a little 5amp fuse on the left side of the two banks of fuses first 5amp left side top to bottom
god only knows what that controls but it lets the ignition be turned on but the starter does not get power i.e no click everything else in the car seemed to work. Doors lights sterio nav
And no warning lights or ODBII codes
Interesting
TTYL
Simon
Old Jul 24, 2011 | 08:09 PM
WhiteXKR's Avatar
Simon-
Please tell youir wife we need her on this forum!
Old Jul 24, 2011 | 09:19 PM
Gus's Avatar
Gus
Originally Posted by WhiteXKR
Simon-
I echo your comments!!
Kudos to her! You are on the road again!
philwarner
Dec 6, 2021 07:13 AM
tberg
Sep 7, 2015 07:32 AM
johanasu
Sep 3, 2015 12:39 PM
1964Daimler
Sep 2, 2015 11:41 PM
GreyXK
Aug 31, 2015 05:15 PM
