Engineering the Perfect Hydraulic Pressure Reduction System
Old Nov 12, 2011 | 09:46 PM
  #41
WhiteXKR's Avatar
No, I was not monitoring voltage, but I can.
One of the problems is the data recorder I am using is a really low end unit only capable of sampling at 120 times per second, so it cannot resolve the 22 KHz PWM signal. Also, though the scope I have can resolve it, but does not have a deep enough memory to get a meaningful picture over a long enough time period.
I think I will try to temporarily lower the PWM frquency way down, to say 30 cycles per second for test purposes. Then I can resolve the data with the equipment that I have. Maybe then I can get some more clues and see if there is a way to predict when this is going to happen and alter the drive somehow to prevent it.
Old Nov 13, 2011 | 06:33 AM
  #42
Dennis07's Avatar
I'd like to suggest some caution here. The PWM idea, as generally applied, counts on the PWM frequency being too high for the driven device to detect the pulses ... and so to react just to the average voltage.
Not sure how the motor will react to pulses as slow as 30 cps. It will likely "feel" them. Maybe OK, but worth going slow here I think.
toronadomike
Jan 22, 2026 10:13 PM
D.K
Dec 10, 2023 02:05 AM
Russ Graber
Feb 23, 2019 11:59 AM
johanasu
Sep 3, 2015 12:39 PM
TC Johnson
Sep 2, 2015 09:30 AM
