Exhaust Manifold Bolt Re-use?
Old Mar 17, 2018 | 09:39 PM
jobagadonuts's Avatar
Default Exhaust Manifold Bolt Re-use?
Aloha All,
I'm in the middle of a head gasket r/r and am in the process of re-installing the exhaust manifold to the head (already removed from the block) The Jag shop manual does not recommend reusing the manifold bolts due to a "locking patch". I've wire-wheeled the bolts of any anti-seize and debris and they look fine. Am I missing something here? The bolts are $10 each and I'd like to save where I can.
Thanks in advance!
Old Mar 18, 2018 | 04:23 AM
phanc60844's Avatar
You have to balance future failure or failure in refitting against the cost of new, its your choice. I would say it was a low risk in this instance so I'd reuse
Old Mar 18, 2018 | 02:01 PM
astromorg's Avatar
The only reason for using new bolts in this situation is to get ones with a dollop of thread lock ready applied for you! If you feel competent to apply thread lock to the original bolts, that'll be fine! Not much chance of stretch/failure with a recommended torque of 16 - 20 Nm.
Old Mar 19, 2018 | 04:17 AM
I re-use manifold to head bolts but NEVER re-use manifold to front exhaust studs and nuts.
al_roethlisberger
Mar 20, 2016 06:08 PM
Time-Pilot
Nov 2, 2013 06:23 PM
rustfreemike
Jun 25, 2012 09:17 PM
TopHatChef
General Tech Help
Mar 4, 2012 02:06 PM
hoodun
Feb 7, 2012 07:14 PM
