A few switch and light questions
Old Jan 1, 2013 | 02:21 PM
Sentinelist's Avatar
Default A few switch and light questions
1. What is the red light in the driver's side air vent? It seems to turn on briefly and match a 'ding' on startup.
2. What does the Valet button do?
3. What does the knob next to the Valet button do? It's broken off, but appears to have about 300* of turn to it.
Thanks!
Old Jan 1, 2013 | 07:47 PM
Spurlee's Avatar
Judging from the red light and knob I suspect you have an aftermarket radar or alarm installed.
The Valet button disables the trunk latch to keep people out. There should be a green key to give the valet. Mine went missing and I disconnected the Valet feature.
Old Jan 1, 2013 | 10:00 PM
Yep, no green key came with the car- looks like I have two switches to disconnect.
Interesting if that's an aftermarket detector switch... I have a V1 detector.
Old Jan 4, 2013 | 12:32 AM
Spurlee, you were right! I met the previous owner (Cerberus66) today, and he confirmed that's a K40 system. Glad I didn't disconnect it! Will probably play with/relocate the receiver behind the grille and keep this intact after looking up more on the specifics of what I have here. That's what the light in the air vent is for as well. Very cool.
Old Jan 14, 2013 | 08:28 PM
Spurlee's Avatar
Good to know!
Old Jan 14, 2013 | 08:45 PM
Jag#4's Avatar
I do not have the valet key either, but I use the valet button all the time. Once engaged, the trunk can only be opened if the black key is put into the ignition to disable the valet mode.
This is very useful if you want to leave your top down in the parking lot for a quick run into the store or wherever and not worry about any valuables in the trunk.
However, you will get some funny stares when the door lock chirps to set the alarm and you walk away with the top down.
Forcedair1
Sep 8, 2025 01:57 PM
D.K
Dec 10, 2023 02:05 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
arnoldmilk
Sep 3, 2015 07:42 PM
laserguy
Sep 3, 2015 02:02 PM
