Filter box mount replacement?
Old Feb 9, 2010 | 03:57 PM
hallam's Avatar
Default Filter box mount replacement?
I have been getting the dreaded 'reduced' message and the P0171/P0174 error codes.
So at first I thought that the cause was likely a grubby or broken mass flow. While taking that out I noticed that the rubber mount holding the filter box in place had perished. There was also a noticeable gap round the connection between the air hose and the mass flow.
What I suspect is happening is that the filter box is wobbling about to a much larger degree than spec and that as a result the air hose is being pulled out of its mounts creating air gaps that let air in.
So I have been trying to find the filter box description in my EBay technical manual. To no avail, looks like they didn't include that part. I must say though, that it is absolutely one of the worst E-Book type applications I have ever come across. Finding diagrams is impossible. I do have a degree in nuclear physics, the e-book manual is a pieced of crud.
What I need to know is what the part number of the filter box mount would be. It is a little rubber/neoprene pillar about an inch high with a mounting socket for a screw.
Any ideas?
Old Feb 16, 2010 | 02:34 PM
daddyo007's Avatar
Is it number 5, 6 or number 12?
Available from here. http://www.jpamporschejaguarparts.co...layCatalogid=0
Last edited by H20boy; Feb 16, 2010 at 04:42 PM. Reason: tiny attachment hurts eyes :)
Old Feb 16, 2010 | 06:12 PM
GordoCatCar's Avatar
Get number(s) 5. and 6. Simple to install. Stop your air box from shaking and moving about.
Old Feb 16, 2010 | 06:31 PM
hlgeorge's Avatar
What year is your car? There are some differences.
Old Feb 17, 2010 | 10:25 AM
BobF's Avatar
I had the same problem on a 99 XK8, the seperation was caused by the motor mount failing. Replaced both motor mounts, the seperation between the broken airbox mounting parts was removed. Replaced the mount and no further problems.
A failed motor mount will have oil leaking from the unit, also look for excessive engine movement when increasing RPM from idle.
BobF
Old Feb 17, 2010 | 07:18 PM
hlgeorge's Avatar
I have also replaced the motor mounts on my '01 XKR. One was leaking and the other was totally dry. A lot less vibration feel after replacement.
Sprayall
May 30, 2021 08:13 AM
Sprayall
Sep 3, 2015 07:49 PM
laserguy
Sep 3, 2015 02:02 PM
pnwrs2000
Sep 3, 2015 11:55 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
