Flexplate/Flywheel Dimensions
Old May 23, 2024 | 12:55 AM
XKRJGR's Avatar
Default Flexplate/Flywheel Dimensions
Hello All, new to the forum and would love some help if possible. I am going to manual swap my 2000 XKR and am planning to machine a custom flywheel to suit the S-Type six speed I have. I have not started the disassembly process yet and won't untill I have all the parts I need. I was wondering if anyone has a spare x100 flex plate that they could help me with some accurate dimensions? I am modelling a 3D design of the flywheel and plan on making it free for everyone to access once complete. Please see the attached image of the dimensions I need and the beginnings of the flywheel design.
Thank you
Old May 23, 2024 | 09:00 AM
motorcarman's Avatar
The timing segments need to be AJ27 or the engine will not run correctly.
X308 sedan torque converter drive plate will work also.as long as it is AJ27.
Old May 23, 2024 | 06:57 PM
XKRJGR's Avatar
Thank you, I plan on retaining the original flex plate with its timing marks. The new flywheel will serve as adapter to that and the clutch, much like the attached examples.
FYSAS
Jul 13, 2025 09:06 PM
irab88
General Tech Help
Dec 27, 2023 06:58 PM
JAG-NOIR
Aug 12, 2022 08:44 AM
Jaguar1611
Dec 17, 2021 11:03 AM
frenchfairplaydriver
XJ40 ( XJ81 )
Sep 19, 2017 11:46 AM
