Fob and key will not unlock door or trunk
Old Jan 28, 2010 | 09:46 AM
GregC's Avatar
Default Fob and key will not unlock door or trunk
Hi, I'm a new member and you can read about me in the new members area. This is a great site! I've owned my 98 XK8 convertible for almost two years. The other evening I parked it and locked it using the fob as I always do. The next morning I go out to the car and click the unlock button and nothing. I tried it again and again and still nothing. Trunk...nothing. I figure a bad battery so I replaced that the next day and came home and still the same results! OK so I start doing some research...I took the fob apart and cleaned all the contacts with a Q-tip and alcohol and put it all back together. Still nothing. I tried using my key to open the trunk...nada. I tried the key in the door and again nothing. I'm going to call a locksmith out here tomorrow if I can't find a solution. I suspect it's a fuse. HELP!
Thanks!
Old Jan 28, 2010 | 10:05 AM
Brian2000XKR's Avatar
Welcome to the Forum! I'm no expert, but there are many here and one will probably chime in here. To me, it sounds like a bad Car battery. There is a hidden keyhole in the XK8 badge on the right rear corner of your car. You can open the trunk manually and check the battery (right side of trunk). I think that is a good starting point for you.
Good luck,
Brian
Old Jan 28, 2010 | 10:12 AM
Brutal's Avatar
Lube the locks with oil and do it again. Common issue with remotes these days, no one uses keys anymore and when you do the locks are frozen. And yes probobly dead car battery. The boards in the remotes do go bad though which is why they have to be replaced
Old Jan 29, 2010 | 06:26 AM
GregC's Avatar
Thanks! That was it...dead battery and locks that needed lubed. I work for a mass transit company and talked to our mechanics about this issue...everyone wants to "mystify" the Jaguars...they kept coming up with some no sense reason...must be a super duper security lock on the system. I kept telling them, "It's a luxury sports car with 4 wheels and an engine...it can't be that difficult." Thanks again...
Old Jan 29, 2010 | 01:53 PM
H20boy's Avatar
congrats Greg, who knew lube would be your solution?!?
Hope you stick around for some cuddling.
Old Jan 29, 2010 | 03:43 PM
Matt, you're a bit twisted....................but I like that in you!
Brian
peterg19
Feb 10, 2023 09:02 PM
XJsc-guy
Nov 23, 2015 01:56 PM
kabs3012
Sep 12, 2015 10:40 AM
kabs3012
US Midwest
Sep 10, 2015 01:17 PM
Jay48
Sep 7, 2015 09:30 PM
