forward a drum fixed
Old May 13, 2012 | 09:03 AM
rr01's Avatar
Default forward a drum fixed
BIG THANKS to this forum & members I was able to fix cracked forward a drum in the trans. Thanks for the information posted give me confidence to attempt this task. It wasn't easy but I was able to complete job without any assistance. Now we're roll n again! Thank-you Lord!
Old May 13, 2012 | 11:41 PM
H20boy's Avatar
so, no story to precede the big repair job? i'd like to hear the whole grueling tale.
Old May 14, 2012 | 06:44 AM
rr01's Avatar
I followed the thread "p1722, no tranny shops gonna get all my money." Pretty much the same scenario as this poster. I was leaving my home car would not pull in drive. Scanner read p1722 fault . Pulled trans forward a drum cracked .Ordered new one from transmission & parts technology. Ordered new seals from eriksson industries. Print off zf trans manual from this forum. I kept internal parts in order & took pictures . Used the zip tie trick to aline clutch paks. Pretty tricky getting the drums lined up w/ paks. After several tries got them all back in. Once got the a/b drums back in the case did the measurement of approximately 20mm ( in zf manual ) . Once I returned trans in car she shifted normal. This probably would have been a little easyer with some assistance but I got it done. Thanks to this forum.
Old May 14, 2012 | 06:46 PM
H20boy's Avatar
wow, mucho congrats! if you ever want to document the rebuild you did with pics, I'm pretty sure we don't have a detailed writeup for it. Parts links, prices, step by step, and you'll immortalize yourself in jaguarforum for all time.
Old May 14, 2012 | 08:17 PM
plums's Avatar
There is nothing quite like doing your own. As you roll down the road, you know exactly what is inside.
aholbro1
Dec 29, 2024 06:46 PM
bamforp
Aug 14, 2024 05:36 PM
kevinl
Oct 31, 2019 06:15 PM
1964Daimler
Oct 3, 2015 12:18 PM
JimMLiny
Sep 9, 2015 08:13 PM
