Front Alignment Shims
Old Feb 9, 2022 | 01:23 PM
Jerry Lippmann's Avatar
Default Front Alignment Shims
Hi,
During disassembly of the upper wishbone to preform replacement of the shock/spring/upper plate assembly, it was apparent that P.O. or his mechanic had been in there and some of the shims were missing. I have only a total of 4 thin for both sides.
Does anyone know of a source for these? Alternately, the inside diameter and outside diameter? I see the thicknesses defined as 0.9mm (thin) and 1.6mm (thick), and can source these if I know the size.
Any information would be appreciated.
Thanks,
Jerry Lippmann
1999 XK8 152Kmi
Old Feb 9, 2022 | 03:23 PM
kstevusa's Avatar
Jerry, the Shim Part #'s for thick are MJA1467AA and Thin is MJA1467BA. 4 thick and 4 thin are needed for total of 8 shims for both sides. I was short 1 thin ship and order from Engel Import Parts in Kalamazoo Mi.
Old Feb 10, 2022 | 09:02 AM
Dr. D's Avatar
It is worth noting that the right side and left side shim arrangements in kstevusa attachment are not symmetrical. Although it may appear questionable, it is correct.
Old Feb 10, 2022 | 02:04 PM
michaelh's Avatar
The asymmetry is related to road camber, I understand.
The default shim arrangement is a mirror image for RHD cars
NB there is an error. Note (1) should read 0.4° not .04°
Old Matelots
May 10, 2021 03:32 AM
alanroberts50
Apr 20, 2021 01:58 PM
Jandreu
Aug 20, 2019 07:46 PM
jeremys
Oct 20, 2017 10:41 PM
YYC guy
Jun 27, 2017 08:35 PM
