Front end wobble when braking
Old Apr 14, 2009 | 02:12 PM
H20boy's Avatar
I'm no suspension expert, though I have replaced almost everything under her, but I would suspect a random 'redirection' may be caused by a control arm, or even an extremely worn bushing(s). There's other suspension guys on here that can help you morso than just me....thank goodness.
If you think it is brake caliper related, you can always rebuild the calipers, or at least lube the caliper pistons (<- don't know the technical term) to make sure there isn't any 'bias' from one side to the other.
Old Apr 15, 2009 | 12:47 PM
H20boy's Avatar
I've heard that worn control arm bushings will allow the car to wander. Braking applies more force to these parts as well. Does the steering wheel turn with it, or does it remain steady?
Old Apr 16, 2009 | 08:33 AM
GreenJewel's Avatar
I have a slight pull to the left. New pads and rotors. I think my caliper isn't releasing as it should and is dragging. More break dust on the left front wheel than on the right.
Once the pads heat up then the pulling stops.
dsnyder586
Dec 29, 2024 07:39 PM
PMKimpton
Aug 3, 2019 08:22 PM
Jeh
XJ40 ( XJ81 )
Oct 13, 2015 09:23 PM
jdzubas
Oct 4, 2015 09:14 AM
KarimPA
Sep 12, 2015 08:15 AM
