Front hub removal question
Old Mar 29, 2023 | 07:38 AM
Stamford's Avatar
Default Front hub removal question
I'm going to be replacing my front wheel bearings on my 2005 XK8. I want to remove the hubs and take them to a shop to have the new bearings installed. From what I can gather, in order to remove the hub assembly I have to pop the upper and lower ball joints, the tie rod joint and the speed sensor on each wheel. Does the assembly then just slide off the axel or is it more involved than that? Thanks for any info.
Old Mar 29, 2023 | 08:57 AM
fmertz's Avatar
I would assume the brakes are going to have to be removed. Calipers will have to be unbolted from their carriers and hung aside, rotors removed, and maybe caliper carriers removed as well.
Old Mar 29, 2023 | 05:04 PM
Stamford's Avatar
Yup, calipers, etc. will come off. Hoping the unit will then just slide off the axel. Will probably take the opportunity to paint the calipers red and the wheels gloss black. Think that will really look great on a silver car with a black top.
Old Mar 29, 2023 | 05:30 PM
fmertz's Avatar
Should not have an axle to even get off of, the car is rear wheel drive.
Old Mar 29, 2023 | 07:37 PM
Stamford's Avatar
OMG - I was seeing my Chrysler van in my mind!! I need an embarrassed emoji.
Old Mar 29, 2023 | 08:27 PM
michaelh's Avatar
LOL - here you go
Ahem, I've used it a few times...
Old Mar 30, 2023 | 07:34 AM
Stamford's Avatar
Thanks so much. You'd think that having just replaced most of the front suspension, I'd remember what it looked like. Getting old is an adventure every day!
Okami
Sep 25, 2022 08:57 PM
yardpro
Apr 3, 2022 08:11 PM
mountain
Aug 29, 2021 10:19 PM
oldmainsfishing
Aug 9, 2009 05:09 AM
CB00JAGUAR
Jun 20, 2008 06:34 AM
