front lower shock bush
Old Sep 16, 2012 | 12:27 PM
dennisw's Avatar
Default front lower shock bush
did my nearside rear lower shock bush on saturday now both done..just showing slight wear but changed it anyway..suspension is now very good but was wondering does the front lower shock bushes go duff..I know I can get them from british parts.. and how easy or hard are they to do..
like to do it all b4 the winter..any advice please..
Dennis
Old Sep 17, 2012 | 05:53 AM
dennisw's Avatar
no replies yet?
Old Sep 17, 2012 | 07:53 AM
Goldlion's Avatar
The front lower strut bushings also degrade like the rear ones do and can lead to declining ride quality. You can check them directly for wear by removing the front wheels. As such, the lower bushings are rather easy to get to and can be replaced on the car or you can remove the whole strut/spring assembly and replace the bushings in the shop. Be careful if you have CATS suspension as the struts can be damaged, $$$, if subjected to a sharp hit.
Old Jan 6, 2013 | 07:28 PM
ccfulton's Avatar
When doing this on the car, how can the bushing be pressed out and the new one back in? Can a tool similar (or the same) as the one needed for the rear be used?
It looks like you can unbolt the shock and then lower the control arm a bit to gain access to the bush but not so far as to bind on the ball joint and damage it.
Thanks all.
Neil1664
Jan 20, 2022 08:59 PM
KarimPA
Sep 12, 2015 08:15 AM
EZDriver
Sep 8, 2015 09:25 AM
Tar
Sep 6, 2015 11:24 AM
Busa R
Sep 3, 2015 05:01 PM
