Front seat creak
Old Sep 21, 2013 | 02:43 PM
RaceDiagnostics's Avatar
Default Front seat creak
Kim's driver seat has developed creak,I found this on JagRepair.com, I hope it works out. http://jagrepair.com/images/TSB/TSB2...0Mechanism.pdf
Old Oct 8, 2014 | 03:14 PM
I had a go at this fix tonight, Kim's car is out side the range that should have the problem and did have the O ring, anyway this is how it went.
I used this video showing how to remove the seat,
and the TSB above for instructions on the fix
Once I unbolted the seat and tilted it back, I found two connectors that needed to be disconnected, the large one has a tab on the top to release and the smaller one has a push tab on the left hand side looking at the picture.
The loom is held in place by a small spring clip and the small grey tube pushed onto the peg in the picture below.
Full underside of seat.
Here is the O ring that is used in newer seats.
I picked it out with a hook, it was hard and brittle.
This is the part recommended in the TSB.
I flattened it a bit with pliers and greased it before installing.
Push fit.
Then tapped home with a small hammer.
I then took the car out for a short test drive, so far no creak but to be honest it seems like an unlikely place for the creak to be coming from, I will report back after a longer journey.
When I got back in the house I found these two brackets on the rug where I had been working, anyone know where they are supposed to go?
Old Oct 8, 2014 | 03:23 PM
Flighty's Avatar
The two brackets belong at the front of the seat runners they fall off as you lift the front of the seat during removal. The front torx screws secure them below the runner At 1:13 seconds in your video
Old Nov 29, 2014 | 05:21 PM
I've been meaning to report back on this, it did not fix the creak, has anyone else had a seat creak and fixed it
Old Mar 11, 2018 | 05:20 PM
rothwell's Avatar
Today I took a shot at fixing this creaking noise in my driver seat. So far so good and not a creak on first outing.
If it does not come back I will post some pics about the fix.
Old Oct 23, 2018 | 09:41 PM
rothwell's Avatar
I realized that I never circled back to this. Creaking is gone in my driver seat now for quite a while. So long I almost forgot about it.
The fix is to lube the pivoting joints that attach the seat back to the lower frame.
The steel parts pass very closely together so lube the crack between them.
Then lube the spring that is stretched along that joint.
Soak it all with WD40 or similar so it works into things well. I am not sure grease will do the job.
Old Oct 28, 2018 | 12:08 PM
steven300's Avatar
its possible you might have a cracked frame,you'll have to investigate further
dsnyder586
Dec 29, 2024 07:39 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
wcourt3010
Sep 9, 2015 04:34 PM
joey g
US Northeast
Sep 7, 2015 06:28 PM
Dallas XK8
Sep 3, 2015 12:17 PM
