Front Shock Bushings
Old Mar 6, 2015 | 07:17 AM
paintfiend's Avatar
I wonder who the manufacturer of the poor bushings was. Mine aren't in front of me so I have no idea. Always chase the threads on a painted, powdercoated or filthy bolt/stud. NOT doing so is just asking for a problem.
If all else fails, this is a complete assembly and I'm sure I can swap out the bad top portion with the original or replace the bolts with something of higher quality. Thanks for the warning, hadn't seen those threads before.
Old Mar 6, 2015 | 04:38 PM
RaceDiagnostics's Avatar
Guys, if you check my thread you will see that I cleaned the paint off and used a torque wrench and the stud sheared off well before the spec torque. You may be lucky or you may not, but beware.
Old Apr 16, 2017 | 03:25 PM
badcat97's Avatar
check out the post of the guy who used plastic cutting boards to rebuild his upper mounts, I myself just purchase a 12x12x.75 inch piece of King-Starboard. Its a marine grade polymer board used for making synthetic marine docks and such. it will resist heat oil fuel. only cost less than 40.00 for the 12x12 sheet and is enough to do both sides and will most likely last longer than the car
Old Apr 16, 2017 | 03:29 PM
badcat97's Avatar
BTW Summit racing sells front bilstien b4's for $101.99 usd. each
Neil1664
Jan 20, 2022 08:59 PM
ym37tech
Feb 8, 2016 01:04 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
KarimPA
Sep 12, 2015 08:15 AM
Tar
Sep 6, 2015 11:24 AM
