Front shock lower bushings
Old Nov 25, 2020 | 02:23 PM
Bob Boyle's Avatar
Default Front shock lower bushings
Is ok possible to replace the lower front shocks without removing the whole assembly from the car? I would like to hear your experience.
Old Nov 25, 2020 | 03:41 PM
giandanielxk8's Avatar
Originally Posted by Bob Boyle
Is ok possible to replace the lower front shocks without removing the whole assembly from the car? I would like to hear about your experience.
And how exactly do you plan on doing this? You're already 50% of the way done once you have removed the lower shock bolt. You're also most likely to have disconnected the sway bar. At this point, the three top screws to remove the shock are a no brainer. And any worthwhile press or c-clamp tool will be infinitely more comfortable to work with on the bench.
I don't see the point in keeping the shock in the car when it's so easy to remove.
Old Nov 25, 2020 | 03:48 PM
Bob Boyle's Avatar
You do have a point.. Thank you.
Old Nov 25, 2020 | 05:24 PM
cjd777's Avatar
I did the rears and all the right tools, painful, but the fronts, even though do able, like above, take them out of the car.
Old Nov 25, 2020 | 05:34 PM
Bob Boyle's Avatar
I'm starting to see a trend in the responses... Thank you for your response.
Old Nov 25, 2020 | 06:13 PM
xalty's Avatar
on the 308 you can do the rear lower shock bushings if you have the rear on ramps and put about 4-500+ pounds of stuff in the trunk, maybe the 100 is the same.
fronts are easy though, might as well get new shock mounts while you’re at it
Old Nov 25, 2020 | 06:55 PM
Bob Boyle's Avatar
I agree with your last sentence. Thanks for taking the time to reply.
oteymus
Apr 11, 2020 10:56 AM
RJ237
Apr 16, 2017 03:29 PM
reb1999
Feb 22, 2017 08:36 AM
Jon89
16
Jan 18, 2017 02:10 PM
EZDriver
Oct 14, 2012 05:07 PM
