Front shock lower bushings
And how exactly do you plan on doing this? You're already 50% of the way done once you have removed the lower shock bolt. You're also most likely to have disconnected the sway bar. At this point, the three top screws to remove the shock are a no brainer. And any worthwhile press or c-clamp tool will be infinitely more comfortable to work with on the bench.
I don't see the point in keeping the shock in the car when it's so easy to remove.
I'm starting to see a trend in the responses... Thank you for your response.
on the 308 you can do the rear lower shock bushings if you have the rear on ramps and put about 4-500+ pounds of stuff in the trunk, maybe the 100 is the same.
fronts are easy though, might as well get new shock mounts while you’re at it
I agree with your last sentence. Thanks for taking the time to reply.
Jon89
16
Jan 18, 2017 02:10 PM
