Front Suspension
My recently purchased 2000 XK8 has a low front suspension. I have read that this is a common problem. Before changing the springs has anyone used spacers ? Do they work ?
You probably do not need to replace the springs, but more likely need to replace the upper shock mounts... they deteriorate over time and definitely need to be replaced. I would recommend the mounts from Welsh Enterprises HERE - they are much sturdier and robust than the OEM mounts and should last much longer.
To answer your other question: I've read several posts about adding spacers. It is just a temp fix.
I agree with Blindside.
FWIW I replaced front springs, it raised height but I saw a bigger difference with the shock mounts. I advise you to stick with the Welsh link. Other brands can be problematic .
John
John
carter333167
Nov 27, 2012 10:24 PM
Jayshmie07
Jul 8, 2012 04:24 PM
MANIACK
May 30, 2012 09:06 AM
catniped
Apr 19, 2012 11:13 AM
jaguarNeWb
Dec 1, 2010 09:42 PM
