Front VEE Mounts
Old May 24, 2020 | 11:12 AM
MattArnold's Avatar
Default Front VEE Mounts
Hi Guys,
how do I check if my VEE mounts need replacement? What symptoms do they have and what to look for on inspection?
What’s the process to change these? How tricky is the job to do?
Many thanks.
Old May 24, 2020 | 11:36 AM
PKWise's Avatar
Default X100 Front Vee mounts
The 2 front Vee-Mounts are Aluminium and mounted very low between the subframe and inner bodywork close to the steering column. They are prone to corrosion and when they start to go, their rubber parts can de-bond which will lead to woolly handing and clonk noises. Vee mounts support the weight of the engine so replacing them is a bit of an effort. The JTIS has a good procedure for their replacement which includes supporting the weight of the engine and dropping the front subframe. See these pics
Support Engine
New Vee-Mounts
Corroded and De-bonded Vee mount
SubFrame dropped
Old May 24, 2020 | 11:40 AM
PKWise's Avatar
Default Front Vee Mounts
Also, this is where the Vee-Mount is - as visible from within the Wheel well.
Old May 24, 2020 | 12:03 PM
PKWise's Avatar
Attached is the Jaguar procedure for X100.
File Type: pdf
Old May 24, 2020 | 12:57 PM
MattArnold's Avatar
It was an advisory on last year’s MOT inspection, but the guys who did it this year didn’t think they needed changing. So I planned to have a look myself. The car can have a slight weave on an uneven road surface, but it’s always done this since I’ve owned it. On a smooth surface it always feels fine.
Old May 24, 2020 | 02:33 PM
PKWise's Avatar
There is an element of fail-safe in the Vee-mount design and this is perhaps why you get thru MOT. Even when de-bonded, the weight of the engine keeps these mounts engaged. However, under certain conditions (such as heavy acceleration load and an uneven road surface) there is tendency for one side of the engine to want to lift which is when a knock can be noticed.
Old May 24, 2020 | 04:23 PM
MattArnold's Avatar
definitely don’t have or ever have had a knock. A little tendency for the car to wander on uneven roads. And perhaps some shimmy over bumpy surfaces on hard acceleration.
Old May 25, 2020 | 03:49 PM
PKWise's Avatar
Those are mild conditions. May be nothing wrong with it!! or perhaps just a sign of suspension bushes starting to go. I certainly wouldn’t commit to do the Vee Mounts unless you have to - you need more symptoms and evidence. It can be one of those frustrating jobs that shear bolts as you go...
leo_denmark
Jul 23, 2019 02:16 PM
David Dougherty
Nov 13, 2017 11:34 AM
Britrover
Mar 10, 2016 10:49 PM
guncharmer
Jun 14, 2011 09:54 AM
bigwiki
Apr 4, 2010 02:22 AM
