Front wheel bearings
Old Apr 12, 2019 | 07:53 PM
EZDriver's Avatar
Smile Front wheel bearings
I am starting to hear noises like my front wheel bearings are going out. With only 68K miles I would thing that is way too soon. What is the best test to determine if that is the case?
Old Apr 12, 2019 | 08:27 PM
johns55's Avatar
Jack up the front, grab the tire at 12:00 and 6:00. Pull hard in both directions and see if you feel any movement. Usually, if the bearings are bad enough that you hear noise, you can feel movement in the wheel.
Old Apr 13, 2019 | 01:43 AM
DavidYau's Avatar
Default Changing the X100 wheel bearings isn’t really a DIY job
Good and bad news for you. Good - The sealed wheel bearings are good for many more miles than yours.
Hope for your sake it’s something else like upper shock mounts .... as otherwise
Bad news to change the wheel bearings out, it’s not like other cars. For us, you will need a seriously BIG press to get them out/in
Old Apr 13, 2019 | 09:12 AM
Johnken's Avatar
Mine wore out about same milage as yours. A $150 harbor freight press will do the job. If I could do it so can you I'm sure.
We've got plenty of instructions here if you decide to go it on your own. Some would point out that the local auto parts store with a press can do the job cheaply too. Just bring them the wheel hub and carrier. Think it was around $40 around here.
It'll be an all day job for both sides. Hope this helps you weigh your options.
John
Old Apr 13, 2019 | 11:01 PM
Ungn's Avatar
Mine growled during lane / direction changes. They are "sealed bearings" but there isn't even a discourager to keep water out. Driving through a wash in a Texas rain storm will doom them.
When Jeremy Clarkson drove an XKR through the surf on Top Gear, my only thought was "well, those bearings are toast".
With a press, getting the Nut off is the only tough part (if the car was ever driven on salty roads, cut the old ones off/buy new). To get the nut back on, buy a 2" 12 point socket. I have the official Jag socket and its not worth the trouble.
Old Apr 14, 2019 | 10:03 AM
EZDriver's Avatar
Thanks everyone fro responding. I believe it was a false alarm. I think it is road noise from the tires. There is no noise when making a sharp turn and it varies depending on how smooth the road is. Some of our roads have a rough texture. When I hit a really smooth spot it goes away. At least I hope it is road/tire noise.
Thanks again guys.
Old Apr 14, 2019 | 01:10 PM
Ungn's Avatar
That is great news. When the bearings are going out, you'll know it. It is a more metallic growl than tires and the growl even gets louder with non aggressive steering wheel movements, that don't put a a bunch of extra load on the tires.
lotusespritse
May 7, 2019 04:00 PM
Sparkers69
Aug 15, 2013 02:35 PM
jrwb
XJ40 ( XJ81 )
Oct 30, 2011 06:38 AM
97xkay8
Mar 4, 2011 05:20 PM
H20boy
Mar 18, 2008 11:13 AM
