Frying Diodes
Old Aug 13, 2011 | 09:53 PM
elkriver's Avatar
Default Frying Diodes
I've recently gone through two alternators on my wifes 99 XK8 in a span of about 2 months. In both cases a diode has gotten very hot and the alternator no longer charges. I would like to know if there is any common problem with the XK8 that can cause this diode death. These alternators are a real pain to replace.
Old Aug 13, 2011 | 10:06 PM
WhiteXKR's Avatar
Have your battery checked first. If that is OK, check your battery to alternator cables for broken strands or corrosion. Also check the high current fuses and associated connections in the the trunk.
Bradley Chambers
39
Feb 11, 2016 10:55 AM
Jpav27
Sep 26, 2015 03:33 PM
Jaguar Forums Editor
Jaguar Press release
Sep 25, 2015 11:58 AM
jjd
Sep 20, 2015 09:46 AM
