fuel filter and grease job
Old Apr 6, 2011 | 04:32 PM
Rev's Avatar
Rev
Default fuel filter and grease job
We bought a 1998 xk8 for a weekend driver, While checking out the car I found grease zerts on the half shafts but none on the driveshafts, are there any more hidden grease zerts I don`t know about, I have change the oil and want to change the fuel filter, how and where do I bleed the pressure off from the fuel system, I asume it is under pressure at all times and don`t want to get sprayed with fuel. also do I remove the nut in the center of the fuel filter bracket or remove the bracket completely from the floorboard.
Old Apr 6, 2011 | 05:03 PM
H20boy's Avatar
Rev, I actually changed my fuel filter w/o doing anything special...except keeping the key out of the ignition. If you unbolt it slowly, you can contain the spilled fuel easily...and bleed the remaining pressure, I think maybe 4-6 ounces came out upon disconnection.
Old Apr 6, 2011 | 05:14 PM
billm's Avatar
I also only found a total of 4 Grease Fittings at the rear, 2 on each half-shaft. Would also be interested to find out if there are any others hiding some where...
Old Apr 6, 2011 | 06:50 PM
Rev's Avatar
Rev
H20boy,
Thanks, went right out there and swapped it out with no leaks,
Old Apr 6, 2011 | 10:40 PM
Reverend Sam's Avatar
I'm confused.
Old Apr 6, 2011 | 11:05 PM
H20boy's Avatar
Originally Posted by Reverend Sam
I'm confused.
wait for it.... -->
Old Apr 6, 2011 | 11:26 PM
Danster's Avatar
I love how Sam responds to his own posts.
silkcat
Jan 18, 2025 04:29 AM
dsnyder586
Dec 29, 2024 07:39 PM
bamforp
Aug 14, 2024 05:36 PM
chatmanx
Sep 11, 2015 07:17 PM
Sprayall
Sep 3, 2015 07:49 PM
