Fuel Filters locations
Old Feb 1, 2018 | 12:23 PM
br549's Avatar
Default Fuel Filters locations
I am (br549) I have a 2000 XK8 ,4.0 motor 67,000 mile convertible . It won,t start. I think it might be Fuel pump,I also need to check the fuel Filters. Would some one please tell me how and where the inline fuel Filters are and how to get to them to change them? I have checked everything but these,I have no fuel at the rail schrader valve test port . Thank to all who can Help me br549.
Old Feb 1, 2018 | 12:37 PM
fmertz's Avatar
Fuel filter is forward of the driver side rear wheel. It is sort of deep in the wheel well. You need to look around. There is a bracket, and 2 fuel lines. Best to take the wheel off.
Check the inertia switch, too, I suppose (driver side fuse box, side of the dash, when you open the door).
Old Feb 1, 2018 | 12:41 PM
avern1's Avatar
The fuel filter is on the left side of the vehicle in the area under the rear seat pan. I have attached a picture from the tech manual
Follow this link and you can see the steps and photo's for replacing the fuel filter and for replacing the fuel pump.
JagRepair.com - Jaguar Repair Information Resource
Old Feb 1, 2018 | 12:44 PM
avern1's Avatar
fmertz makes a good point. Check those things and also check fuse #7 in the boot fuse box and you will also see a set of relays arranged as a tee. You can swap the fuel pump relay with anyone that is the same color.
Old Feb 1, 2018 | 01:48 PM
Originally Posted by avern1
The fuel filter is on the left side of the vehicle in the area under the rear seat pan. .....
The drawing in Vern's post #3 makes it look a lot easier to get at than it really is.
Old Feb 1, 2018 | 05:20 PM
avern1's Avatar
+1 GGG, it is a real bugger to find and then replace. But the bracket in the picture will get you in the area.
Old Feb 1, 2018 | 07:57 PM
XK8 Rebel's Avatar
And +1 on removing the drivers side rear tire to get access. I hardly see how it could be done without doing so. Tough to get your hands in there.
Several folks indicated that very little fuel escaped during the filter replacement. That was not my experience. Have a container ready.
Old Feb 1, 2018 | 10:54 PM
Johnken's Avatar
Re: fuel filter replacement. I see several of us mentioned fuel spillage. Don't forget that if you pull the fuel pump fuse while she is idling, the engine will relieve fuel pressure before it stalls, I find you'll then only see an ounce or two of gas will spill from the filter connection.
Hope this helps.
John
Old Feb 2, 2018 | 05:05 AM
Originally Posted by Johnken
..... pull the fuel pump fuse while she is idling, the engine will relieve fuel pressure before it stalls .....
John,
I'm always a wary of this technique. Although it sounds logical and does work, Jaguar advice is never to run these vehicles out of fuel. Do you get any DTC's on the restart after doing it this way?
Old Feb 2, 2018 | 08:20 AM
avern1's Avatar
I too, am not a fan of running a Jag out of fuel. The easier way is with the key off you put a rag over the schreader valve, depress it and relieve the rack pressure.
Old Feb 2, 2018 | 08:43 AM
Johnken's Avatar
Vern, Graham, no I never had any codes or problems. Thanks for the heads up though. I wonder if the Jaguars warning is to protect the fuel pump. For folks just joining - if you pull the fuse pump stops as though ignition off, gas tank still full.
John
fgkell
Mar 14, 2015 01:08 PM
rayclark1
Jan 6, 2015 04:03 AM
LecXJ6
Jan 28, 2014 03:53 AM
ka1thm
Aug 2, 2011 08:00 AM
ancientsanskrit
Jan 27, 2008 04:57 AM
