fuel gauge issue
Old Mar 11, 2012 | 11:18 AM
skubeedoo's Avatar
Default Same Issue
My fuel gauge is also not correct. Full is about 3/4 and empty, don't know, but I'm guessing around 1/4. OregonJag mentioned: a loose connection to the instrument cluster. I feel this might be true with my issue because it will remain like this for a month or two, then the gauge will "readjust" to a new position and remain there for awhile.
Where can I find the "connection to the instrument cluster?"
Old Nov 19, 2012 | 09:26 PM
yyk's Avatar
yyk
Default Fuel gauge Sender issue
I just saw on Motor Week last week that high sulpher in gas can cause the silver in the variable resitance unit to corrode and before attempting a mechanical fix you can try a BG gas additive to remove the corrosion in the sending unit silver to correct the problem. Not sure which additive but the can is gold colored with white letters.
Mike
'00 XKR Coupe
Old Mar 13, 2018 | 01:00 PM
mikegs50's Avatar
Default fuel gauge
01 XK8
My fuel gauge has not worked for two years.
The car developed a slight stumble and I was advised to add JB 208 to my fuel. Now the stumble is gone and my fuel gauge has come back to life. NOW I will use JB products on a regular basis.
Old Mar 13, 2018 | 03:37 PM
Jon89's Avatar
Hmmm, I wonder if the JB 208 fuel additive product actually resolved your fuel gauge issue. Perhaps hitting a nasty pothole or bump jarred your fuel gauge float out of its stuck position. No way to really know, I suppose....
toronadomike
Jan 22, 2026 10:13 PM
99xk8guy
May 28, 2024 09:36 PM
giandanielxk8
Sep 6, 2015 07:21 PM
AL NZ
Sep 4, 2015 08:39 PM
Bcrary3
Sep 3, 2015 03:48 PM
