Fuel injector relay
Old Aug 28, 2013 | 09:38 AM
giandanielxk8's Avatar
Default Fuel injector relay
Where is it located? I'm going to finish the tensioners job today, I'm already out of my last class of the day. I know I need to disconnect the relay and start the car so that oil is pumped around the tensors, as per Steve's instructions.
Old Aug 28, 2013 | 10:37 AM
WhiteXKR's Avatar
Passenger side, under the hood, under the black cover, by the firewall:
Old Aug 29, 2013 | 09:14 PM
Is it the third wire harness to the left?
Old Aug 29, 2013 | 09:20 PM
WhiteXKR's Avatar
Whoa man. Put that cover back on...don't mess in there. The relays are the black cubes OUTSIDE of the sealed compartment.
Old Aug 29, 2013 | 09:24 PM
Ok, thanks, so which of the black cubes? I have two on top and a third one below those two?
Edit: I think i found it, I lifted one of the black cubes and noticed the fuse-like squares. According to your diagram, that would make it the third one to the left under the right black box.
Old Aug 29, 2013 | 09:32 PM
WhiteXKR's Avatar
Can you take a picture?
Sometimes the relays have plastic snap on covers over groups of 3 relays. The tops of the relays are about 1 inch x 1 inch. I think you are looking at the covers which are about 3 inches x 1 inch.
Old Aug 29, 2013 | 09:36 PM
Is it the third one to the left, edging the other black box?
Old Aug 29, 2013 | 09:38 PM
WhiteXKR's Avatar
Thumbs up
Yes...you got it!
Old Aug 29, 2013 | 09:40 PM
Yes...you got it!
OK, I'm going to start the car now.
Old Aug 29, 2013 | 09:43 PM
WhiteXKR's Avatar
After 5 seconds of cranking or so you can put the relay back.
Old Aug 29, 2013 | 09:45 PM
Done.
Relay is back.
Started the car again....
She's alive!
Old Aug 29, 2013 | 09:48 PM
WhiteXKR's Avatar
Congratulations ! Nice job!
I admire your courage and persistence to take this job on and do it right.
JWheeler
Nov 22, 2019 08:28 AM
ogorir
Jan 18, 2016 10:09 PM
Bigvettefreak
Sep 29, 2015 04:13 PM
ratgawd
Sep 16, 2015 04:15 PM
Bcrary3
Sep 11, 2015 10:36 AM
