Fuel Injector Retaining clip
Old Mar 17, 2014 | 09:07 AM
Glenn Barickman's Avatar
Default Fuel Injector Retaining clip
I recently sent my fuel injectors out for a good cleaning and I am about to install them. I have been looking for a set on retaining clips but I can't seem to find them anywhere. Does anybody have a source for them or do I need to reuse the old ones. I did find them at a store in the UK, but I got to believe they should be available everywhere. They were also about £4.82 each. I think that is about $7.00 each. That seems high even for a Jaguar. I did read in a forum for another make of car that you really don't need them but I'm not sure that is correct. Has anyone out there found a source for these.
Retaining clip - Fuel injectors, manifold gaskets, throttle body and air filter - Fuel injection and air filter - Jaguar XK8, XKR and XK (1996-2011) - Jaguar - English Cars - SC Parts Group Ltd
Old Mar 17, 2014 | 03:38 PM
test point's Avatar
The XK8 has a vacuum in the injector area attempting to suck them in so no clip is needed. The R has compressor pressure there and that is what the clips are for.
Everything is high for the Jaguar.
Old Mar 17, 2014 | 03:50 PM
This is a clip that holds the injector onto the fuel line. I can't see the injector falling out once all is in place and bolted in. One of my clips is in bad shape so we will give it a try without it.
Old Mar 17, 2014 | 03:58 PM
WhiteXKR's Avatar
See Jaguar Parts - Direct JPLV Porsche Parts.com
Should be a $5.05 list price dealer part.
Old Mar 17, 2014 | 04:04 PM
test point's Avatar
Sorry, thought it was the Supercharged clip that retains the injector into the manifold.
Old Mar 18, 2014 | 07:12 AM
Thank you. Not sure why I couldn't fine one. This forum is the best
Old Apr 21, 2020 | 01:53 PM
rsdmitch7's Avatar
My car '99 4.0
Hi;
Just did mine. No need to buy new ones unless old ones are damaged. Just clean them up and your set to go. Install them in the fuel rail first. With the clips. Very hard afterwards.
I just listed a new post yesterday with instructions.
rsdmitch7
Good luck
Old Jan 8, 2021 | 07:27 PM
ryejag's Avatar
I replaced my aux coolant pump and reinstalled the overflow tank. The fitting at the bottom of the overflow tank, discussed is leaking slowly. I replaced the o ring to no avail. I have not removed the clip and it clicked when reinstalled and it appears pushed all the way in. Any thoughts?
NevadaXK8
Jul 29, 2025 12:59 PM
jaimster
Jun 30, 2020 10:18 AM
rsdmitch7
Apr 21, 2020 02:56 PM
Jagbro
XJ40 ( XJ81 )
Nov 15, 2018 05:30 PM
Hafrod
Feb 11, 2016 11:07 PM
