Fuel pump
Old May 6, 2008 | 12:35 PM
ken@britishparts.com's Avatar
Default RE: Fuel pump
I don't know about the labor. I have the pump for $412.50 and the filter is an extra $57.28.
Old May 6, 2008 | 02:53 PM
test point's Avatar
There has been some conversation about the electrical connector to the pump corrodingand frying itself rather than the pump actually failing. Based on the repair documentation on my car that apparently was what happened, fortunately, under warranty. The dealer replaced the pump, then replaced the connector.
Guess the dealer has your car at the moment. At least you could ask them to check the connector before pulling the pump.
Old May 7, 2008 | 01:15 PM
test point's Avatar
Do a search on this and other forums regarding the ABS. Lots of posts about the right front sensor wiring causing intermittent problems due to strain when turning. Also clean toothed gear on each wheel and the sensors themselves.
Problem could still be the module but that would be the last thing I would try.
dsnyder586
Dec 29, 2024 07:39 PM
Sprayall
May 30, 2021 08:13 AM
JWheeler
Nov 22, 2019 08:28 AM
ccfulton
Sep 20, 2015 05:15 PM
Sprayall
Sep 3, 2015 07:49 PM
