Fuel pump relay location?
Old Jun 27, 2013 | 08:42 PM
Jacsun's Avatar
Default Fuel pump relay location?
I think my fuel pump is shot but I want to check the relay/fuses first. I do not have a manual. Can someone let me know where any relevant relays or fuses are.
I drove today and went to start back up and it cranked, started rough, ran rough, and died after 20 feet. No pressure at schraeder when cranking. Fuel filter is 6 months and 2000 miles. I cranked and let sit and cranked again. Not even close to catching.
Also- I have read about the repeated fuel pump replacements and potential ethanol issue. What kind of pump should I get? Original jag? I cannot find a name brand (Bosch or Denso) pump online for my 2001 XK8. Help?
Old Jun 27, 2013 | 09:09 PM
Gus's Avatar
Gus
Check your other post!
Old Jun 27, 2013 | 09:11 PM
test point's Avatar
You can download the JTIS Service Manual from the 'Sticky's' above.
That will give you both the fuse and relay location you asked about and then you will have a wealth of info for the next issue.
Old Jun 28, 2013 | 03:18 AM
You can also download the full Handbook set (Vehicle Literature Pack) for your XK8 in PDF format from:
https://www.jaguarforums.com/forum/x...-2003-a-67827/
Relay and fuse information is in the Vehicle Care Handbook.
dsnyder586
Dec 29, 2024 07:39 PM
Sprayall
May 30, 2021 08:13 AM
ccfulton
Sep 20, 2015 05:15 PM
Kmw
Sep 8, 2015 04:52 PM
Sprayall
Sep 3, 2015 07:49 PM
