Fuel Pump removal
Old Jan 6, 2026 | 11:42 AM
arachnid53's Avatar
Default Fuel Pump removal
I've already cut the access hole and I've removed the blue plastic sender unit from the tank but I'm not sure how the physically get the pump out of the tank. I can see to fuel hose has to come off but what is holding the pump in the tank. I've done many searches, and I've watched many videos but no luck.
Help would be appreciated.
Old Jan 6, 2026 | 12:34 PM
Tha Driver's Avatar
One little bolt at the bottom of the pump facing down.
Old Jan 6, 2026 | 01:32 PM
arachnid53's Avatar
Thanks, Paul
Old Jan 7, 2026 | 02:29 AM
Pistnbroke's Avatar
xk8 coupe ..pull the back seat out...remove rear shelf cover . using the holes already in the shelf near the speaker hole ,cut two front to back slots in the shelf and bend the flap between out the way ,. Easy access to the top entrance remove ..long drive extension for the nut and pull it out . refit and bend back the flap of metal
Old Jan 7, 2026 | 03:35 AM
bladerunner919's Avatar
I went through the speaker hole in my coupe. Of course, we have no idea what model the op has!
Old Jan 7, 2026 | 03:48 AM
dibbit's Avatar
I would guess as they say they have already cut the access hole they have a convertible and as they have already done it, it's too late to tell them not to if they have a coupe.
First time I've seen the suggestion to cut a flap and bend it out of the way, then bend it back. I wonder if that would be a good solution for the convertible also?
Old Jan 7, 2026 | 07:23 AM
brinny's Avatar
The bolt holding the pump in is a 7mm i believe but may be an 8mm.2 pumps 2 bolts. II did mine by dropping the subframe down. Changed the diff oil while i was at it.
Old Jan 7, 2026 | 12:40 PM
arachnid53's Avatar
Sort of a follow up question on my 99 XK8 Convertible.
I had to cut the 3 rubber hoses that connect the blue sender unit to the hard lines. I ordered what I thought was the correct sizes but they came today and they aren't even close.
What are the correct sizes and where can I get those?
thx
Old Jan 7, 2026 | 03:22 PM
Tha Driver's Avatar
Just measure the blue outlets & buy hose with an ID that size. But here's the thing: make SURE you get ethanol compatible hoses so they won't swell up & weaken!
Old Jan 7, 2026 | 04:05 PM
arachnid53's Avatar
Thanks, I thought I could buy OEM type hoses but that will definitely work.
Old Jan 7, 2026 | 09:52 PM
zray's Avatar
Duplicate
Old Jan 7, 2026 | 09:53 PM
zray's Avatar
have you tried
https://www.sngbarratt.com/
They have most OEM parts that are still available.
Z
Old Jan 8, 2026 | 03:22 PM
arachnid53's Avatar
Originally Posted by zray
have you tried
Z
Thanks for the link. I'll check it out.
berrys
Jul 27, 2021 07:12 AM
Terrance39
Jan 31, 2020 06:04 PM
Paul792
Feb 8, 2018 02:45 PM
mmmagic
Feb 12, 2012 08:58 PM
leestang66
Dec 13, 2009 08:03 PM
